Help! Uxtheme Patch, and Skins Problem!
AlexRD
Well, my problem begins when my aero wouldn't maximize anymore.
(I already patched it before).
So, i tried downloading a skin, on which the aero would stay maximized.
It gave me a CMD command, on which i accepted. ( It wasn't a virus)
But, after i downloaded it, it turns out that my Uxtheme wasn't patched.
So, i lost Windows Vista Basic skins and Aero.
I just have Classic Theme.
I already downloaded VistaGlazz last version, but when i start it, it says that i have to reboot to load some files, so i reboot, and nothing happens, and i try again and i says AGAIN that i have to reboot.
Please, can somebody help me out?
    Asus G2s
    2.20 GHz Core 2 Duo T7500 :\Santa Rosa/:
    1x 2GB DDR2 Kingston ; 1x 1GB DDR2 Kingston
    Nvidia GEFORCE 8600M GT 256mb Dedicated, 768mb RAM
    17" Generic PnP
    1440x1280
    300 GB Fujitsu MHX2300BT 4200 RPM
    ALPS Pointing Device ; Logitech Asus G2 Mouse
    Asus G2s Keyboard from Logitech
    2 MB Wireless Network
Thanks for the help
    Asus G2s
    17" Generic PnP
    1440x1280
This seems to have got into a loop, all I can suggest is running a system files check and see if that resets the Uxtheme.dll
System Files - SFC Command - Vista Forums
Hopefully you will then be able to run the Vistaglass again
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Samsung 32" TV
    68 MB Down 18.5 MB Up
