Help upgrading graphics card
Katokato
Banned
First of all i have a graphics card in mind.
Here it is:
Newegg.com - HIS H483QS512P Radeon HD 4830 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Desktop Graphics / Video Cards
Here is my machine that i plan to put the graphics card into:
HP Pavilion a6110n PC (GG781AA) specifications - HP Home & Home Office Products
also, my monitor uses a VGA cable, how will i be able to convert it and plug it into the dvi ports?
Now i want to know if those 2 are compatible and if i upgrade to that graphics card willi notice a difference?
A guide to upgrading gpu's will also be helpful
Thanks!
-Kelvin Silva
xfire: katokato
Æ£»K¬ă͓͓ṱ ס▓
"Don't worry about the world coming to an end today. It's already tomorrow in Australia." -Charles Schultz
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
sorry for such long sig
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    normal black case
    fans
    dsl
    2.3 ghz amd
    Hewlett-Packard dv6936us
    Intel Core 2 Duo "Merom" T5750, 2 GHz, stock clocking
    stock Quanta 30D2, v.792E
    4 GHz, 667 MHz bus speed
    NVIDIA GeForce 8400M GS, stock
    stock Realtek software-based
    stock 15.4" widescreen
    stock 1280 X 800
    stock Toshiba MK2546GSX and a Western Digital 1TB MyBook
    stock
    stock
    stock plus Rocketfish model RF-LAPCOL
    stock Synaptics Pointing Device
    stock
    Ludicrous Speed (~10.9 Mbps, more or less)
    Browser: Namoroka v1.9.2.3666 64-bit build. Computer specs: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01485288&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=3747246 I like chocolate milk!
its simple just pop it in the open pci-e slot, just make sure your psu is up to it and that it will fit in your case
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
I have bad news, i recently check my computer's psu, it is only 250 watts, ill have to upgrade my psu =(.
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    normal black case
    fans
    dsl
    2.3 ghz amd
hm yes you will i'd try to shoot for at least a 500 watt of a good brand like antec, pc power and cooling, cosair or something like that
    1680 X 1050
    6 Mbs Down 1 Mbs Up
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    normal black case
    fans
    dsl
    2.3 ghz amd
tha psu should work just fine :) you shouldn't have any problem matching everything up as its the same size as the other, and sorry didn't see that you had replied again to your thread :o
    1680 X 1050
    6 Mbs Down 1 Mbs Up
just be sure when you add in the card you disable the onboard graphics in the bio's if it doesn't do it automatically
    1680 X 1050
    6 Mbs Down 1 Mbs Up
okay thanks i think i can disable the onboard graphics through windows, if not ill loook for it in the BIOS
thanks
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    normal black case
    fans
    dsl
    2.3 ghz amd
just make sure you do it after you put in the other card or else your screwed :party:
    1680 X 1050
    6 Mbs Down 1 Mbs Up
so i install my new graphics card then disable onboard graphics or the other way around? how will i get screwed if i disable onboard graphics then install my new graphics?
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    normal black case
    fans
    dsl
    2.3 ghz amd
if you disable before you install you won't be able to see anything :party: so how you would do it is you would install the card, boot windows, make sure it comes up onto the card then restart and go into the bio's and double check to make sure its disabled (usually the motherboard does it automatically but not always) after you make sure its disabled, get back into windows, install the ati drivers, and remove the nvidia one's and your done, and you can prolly leave the nvidia ones if you want i just usually remove them
    1680 X 1050
    6 Mbs Down 1 Mbs Up
okay thanks, in the BIOS theres a section called advanced, and on that section it lists different hardwares. one of them is title video card, and it is currently set to PCI, when i install my card i should switch it to pcie x16 right?
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    normal black case
    fans
    dsl
    2.3 ghz amd
correct, and then you should be set :)
    1680 X 1050
    6 Mbs Down 1 Mbs Up
