Hi all, new to the forums and wasn't sure where to post this, but I need some pretty quick advice.
I recently bought a new PC (at Christmas) and have been running Vista Home Premium x64 since I set it up. However, since roughly a week ago, I have been regularly experiencing problems when shutting down or restarting my PC. The desktop disappears and it appears to be shutting down normally but then it doesn't shut down/restart. After around 5-10 minutes the Blue Screen appears. Then it simply reboots as normal and I receive information on the problem.
This pops up after restarting:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 2057
Additional information about the problem:
BCCode: 9f
BCP1: 0000000000000003
BCP2: FFFFFA8003C88480
BCP3: FFFFFA80065A2050
BCP4: FFFFFA8009D3EC60
OS Version: 6_0_6002
Service Pack: 2_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\Mini011910-06.dmp
C:\Users\Cameron\AppData\Local\Temp\WER-195734-0.sysdata.xml
C:\Users\Cameron\AppData\Local\Temp\WER60D4.tmp.version.txt
I checked the Reliability and Performance Monitor and checked under Windows Failures and found that the failure type was OS Stopped Working.
I have run a diskcheck, used the memory diagnostics tool to check RAM and there appears to be no problems. I would greatly appreciate any help on the issue before I eventually decide to just re-install Vista.
Thanks,
Cameron
Problem signature:
Locale ID: 2057
BCCode: 9f
Service Pack: 2_0
Product: 768_1
Thanks,
Cameron
