Help problem
seebyher
This message appeared today: ATI WARNING
The Catalyst Control Centre is not suppored by the driver version of your enabled graphics adapter. Please update you ATI graphic driver, or enable your ATI adapter using the Displays Manager.
But the thing is I dont know how to do this or what to do can someone help!!!!:shock:
get the ccc from amd and install the newest version and see if that works
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
Go to the ATI Website and according to the model of the graphic card download and install the latest Version of the Driver -
Hey PizzaMan you got Power! Nice.
Hello to seebyher as well.
As said above, update your drivers. Pick them out from the ATI Drivers here.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
Don't use the CD that came with the system or card. Download these from the correct video card....ATI...Sapphire... etc website. Keep in mind that the current version is 8.12 and there are differences between the overclocking features on the CCC. The 4870x2 has the ability for setting the fan speed while the other CCC's seam to not show this, just in case you are wishng to use that tool. They will also show the lower section as 300 but when the card is in use the actual default changes to higher. Riva does show this.
    Home made
    Intel i7 920 Broomfield-Not overclocked
    Gigabyte X58-UD4P
    12 Gig Corsair Dominator Triple Channel 1600 DDR3
    Sapphire 3870 X2 - Just the one now
    Creative Blaster X-FI Titanium Optical to Yamaha Receiver
    Panasonic 50 inch Plasma via HDMI and used as just a Monitor
    1920x1080
    Sata Seagate 750 Gig 32MB for the Vista 64 bit and second drive is Sata 300 Gig for extra storage.
    Cooler Master 1000
    Antec 900 extra fans
    Cooler Master Hyper-N520
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
    LG GGW-H20 Blue Ray writer running with Cyberlink Ultra 9. Home Theater system through Yamaha 7.1 Receiver connected to 11 Def Tech speakers, including powered Def Tech 15 inch sub. What can I say I like movies! Not much of a gamer.
