Help pls
SilksEST
If i install somthing all my 4gb ram is chased ???? i have e2160@3.0gh 4 gb a-data 1066mhz ???? in 32 bit vista i can insatal games normal.
Can please explain a little bit more?
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    8800GTS 512Mb Overclocked
    5.1 surround sound
    500Gb Samsung SATAII XP 500GB Samsung SATAII
    1000W CoolerMaster power supply
    CoolerMaster Cosmos 1000 case
    120mm ThermalTake Big Typhoon CPU cooler, 3 x 120mm exhaust
    Wireless Keyboard and mouse 3000
    1TB WD My Book Office edition external drive x 2, Dual layer LG DVD-Rom burner, 15 in 1 card reader Triple boot: XP, Vista Ultimate 64 and Windows 7 Ultimate 64
when i instal somthing (like game) all ram is used when installing like it instals files in ram in the task manager it shows almost all ram and page file is all used computer is so slow then in xp and vista 32 i dint have this problem ???
Welcome to the board.
I believe the reason your system is slow is not caused by the rams. Please post your system specs so everyone can give you some idea.
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
i have asus p5ql-e ,e2160@3.0ghz , A-DATA DDR2 2x2GB Over Clock Extreme Edition DDR2 1066+ and Sapphire RADEON HD 4850
and using Vista ultimate x64 sp1
Thanks. You have a nice setup. Now let us know what happened unusual such as responding not smoothly, jerking, or freezing and what were you doing while it happens such as playing game or multiple tasking or something?
If there is anything that causes the sluggish, it might have been your CPU. The E2160 Pentium Dual-core 1.8 GHz is not very efficient cpu with old technology. If it is overclocked to 3Ghz, may be a little more tuning is needed.
If there are any consideration in up grading the system, I would start with the CPU.
Good luck and let us know how things going.
    E6850
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
I had this happen once during installation of the game Clive Barker's Jericho.
The installer brought my PC to a crawl while it was copying files across, using all of my 4gb of ram.
It's the only time it's happened for me.
    AMD 5200+
    GA-M57SLI-S4
    4GB Kingston 667
    8800 GTS 320
    Auzentech X-Plosion Cinema
    Chimei 22"
    320gb Seagate Sata 80gb Western Digital Pata
    450watt Corsair VX
    Coolermaster Centurion 534
