Help please
thegamr
I have bought a laptop with windows vista home and i cant play any MMORPG games on it. it starts to update but then say it cant download update list.
The same games work fine on my PC which uses XP pro sp2.
please help me, I really want to play these games on the laptop.
Hello thegamr,
Can you please list your laptop spec's, also what game is it your trying to play, and is it the game update or window's update that is failing ?, thank's.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Intel(R) core(TM)2duo CPU P7450 2.13GHz
Memory 2.00 GB
GeForce 9200M GS
all games I tried didnt work like Deco online, Atlantis, Silkroad online
The game update doesnt work
Are you trying to update from the game browser or is it from a 3rd party site ?
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Try and get the updates from a 3rd party site such as the game developers site. Post your results and good luck.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
I can play someMMOs on my XP laptop; however, I must be in windowed mode. It will crash in full screen mode. 512Megs of ram, 2.1 GHz cpu.
So, you might check for a program in the MMO folder that will let you configure things without running the game, or an ini (initialization) file you can edit in a text editor. Might be in defaults.ini or something like hardware.ini Or a similar filename.
    Acer Aspire X1700
    ASUS
    3 gigs
    EVGA 1 gig GeForce 210
    Vizio 21" tv
    1920x1080 resolution
    fans that came with it
    basic USB
    basic USB
