Help please
adeang
Okay I have a built in wireless adaptor on my desktop computer, but I wanted a better rate of ping, and speed. So, I purchased a 50 ft cat5 or something ethernet cable and I have disabled my wireless adaptor. One question that I have is that how to I enable my wireless adaptor for in future use. My other problem/question is with the ethernet cable hooked up I get a slower ping and my connection is slower when I use the speed test website provided at top. So I would like to know how to fix this and or know why using an ethernet cable seems to be faster, but when checked it way slower.
    HP Pavilion Slimline s3300f PC
    3 gigs
    500 gigs
What process did you use to disable your wireless adapter? If you disabled it in Device manager, then you'll probably need to only re-enable ti in Device manager again - but if you cannot see it you my need to go to View --> Show hidden devices in order to see it to enable it.
If your Ethernet connection is slower than your wireless connection, something is *seriously* wrong - check your Ethernet ports on both the computer and the router you're connecting to and make sure they are not limited - IOW they should be 100 Mbit minimum and 1000 Mbit / 1 Gigabit max. If one is 1000 and the other is 100 that is OK - but if either is 10 Mbit, then you're in for a slowdown, sort of.
It also depends upon what your ISP is providing you with, what type of hardware you have, whether there is a router involved or not, etc.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Okay know how to turn on and off wireless adaptor, but Still want to know about internet speed. I got way higher dl and upload speed and even a better ping with wireless, but when hooked with cord I get like half dl speed about a 20 ms difference in ping as in slower and my upload speed is just a little slower.
    3 gigs
    500 gigs
