Solved Help please 64 bit question
biertonco
i'm running 64 bit home premium and was just installing steam on my pc. it was when i saw where the install was going that i suddenly noticed my programme files name has changed to the x86 instead of what was x64. what has happened and how can i fix it please??
thanks very much in advance
    AMD Athalon X2 6000+
    4GB OCZ platinum
    ATI HD4850
    22" LG
    1680 x 1050
    500Gb seagate barracuda 32mb cache
    600W OCZ stealth
    Zalman
    logitech mx518
    saitek eclipse
Hi biertonco, and welcome to the vista forums :party:
On vista x64 you should have both a Program Files and a Program Files(x86) folder
the Program Files is used for fully 64 bit programs and the Program Files(x86) is for 32 bit programs which will run in compatibility mode
This is totally normal and by design. :D
hope this helps
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Samsung 32" TV
    68 MB Down 18.5 MB Up
tyvm for the warm welcome and help. so has the foder changed name because i have installed a 32 bit programme because i do remember it being x64 before. yes i do however have a folder plainly named programmes. will 64 bit compatible programmes automatically be installed to this. last question does this now mean i am running 32 bit vista or is everything still running at 64 bit.
thanks again
    4GB OCZ platinum
    ATI HD4850
    22" LG
    1680 x 1050
    600W OCZ stealth
    Zalman
    logitech mx518
    saitek eclipse
Yes 64 bit programs will still install to the non (x86) folder. The Program Files (x86) folder was always there, you probably just never noticed it before.
And no you are not now on Vista 32 bit. Vista and any 64 bit programs are all still 64 bit.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
First you are still running x64 :D just running a 32bit application in compatibility mode.
Vista provides a 32bit internet explorer as well as 64 bit so nothing to worry about.
as for the actual naming of the folders I'm not sure as I'm only running x86 vista at the moment.
you may want to check this tutorial article and the links at the bottom of the page for fuller details of x64
http://www.vistax64.com/vista-news/99613-64-bit-more-than-just-ram.html
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
so stormy do you not have a folder called programmefilesx64 either? just wanna know since you are running a 64bit OS
and barman thanks again for you're help, nice link there
edit:
its ok ive checked there are programmes in the 64bit folder too.
    4GB OCZ platinum
    ATI HD4850
    22" LG
    1680 x 1050
    600W OCZ stealth
    Zalman
    logitech mx518
    saitek eclipse
Program Files and Program Files (x86).
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
