Help on Virtual CD/DVD rom
Status
Not open for further replies.
basukinjal
Whenever im installing MagicISO or Daemon tools my Vista says tat it has detected a CD/DVD rom but it need the driver to install it, which i cannot find hence the virtual drive is not installed
Someone please tell me how i can solve this problem so that i can use the softwarse.
Try re-intalling Daemon tools, or uninstall it and use Alcohol 52% instead (Alcohol 52%_).
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
Status
