Help me?!
seantho
ok my sound is freaking me out and i got other problems that just started happening. MY sound is all the way off but i can still hear it through my speakers. and Now Norton is randomly doesn't work and it wont let me do any windows updates. So i dont know whats going on but I need help.
I suggest you do a virus scan.
    Intel Core 2 Quad Q6600 (G0 Kentsfield) LGA775 (FC-LGA6)
    GIGABYTE GA-EP35C-DS3R (Rev. 2.1)
    Corsair TW3X4G1333C9A 4GB PC-10600 (2x XMS3 2GB)
    ASUS nVIDIA GeForce 8800 GT (G92GT/D8P)
    Creative SoundBlaster Audigy 2 ZS/RealTek ALC885/889A/890
    ChiMei CMV CT-730D 17inch (LCD Monitor)
    1280-1024 60Hertz (Ture Colour 32bit)
    Barracuda 7200.10 SATA 3.0Gb/s 160-GB Hard Drive ST3160815AS (RAID0)
    SUPER FLOWER 500watt Plug in Leads 24pin ATX BLACK MODEL
    Thermaltake Shark (VA7000SWA ATX) Full Tower
    Front 120mm fan (1400 RPM) /Rear 120mm (1400 RPM) blue LED
    Cyber Snipa Stinger Laser Gameing Mouse (400-3200Dpi)
    Labtec Media Desktop Y-SAD65
    Telstra BigPond Elite Liberty Cable 17Mbps/256kbps
Hi seantho,
If your Norton is failing & you can't get any Windows Updates you may have
malware.[or a virus.]
It would be a good idea to run SuperAntiSpyware & Malwarebytes to see if they find anything. Both programs have a free version. Reboot after scanning finishes.
Post back results.
SUPERAntiSpyware.com | Remove Malware | Remove Spyware - AntiMalware, AntiSpyware, AntiAdware!
Malwarebytes.org
    IntelCore 2DuoT8300@2.4GHz x2
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
