Help me please
jonocurtis
i am having big vista problems, and i know alot of other people have the same problem, so i hope there is a cure. I can not open control panel,games etc, i can not start software licencing, i can not update windows as they say my windows is not genuine, my Direct x has gone, my cd rom dvd drive spins and recognises disks but can not read them, so i can not use a recovery disk. i have an assus, which i bought in Sydney, but i now live in Moscow, so im stuck, can anybody help me please
damn you are having some problems
i would say try a bootable disc if it recognises discs then it should have no problems reading a disc before windows starts
maybe download or borrow another vista disc to reinstall your vista as it may be corrupted with that many problems, and when it comes to it just use your existing genuine key
i see you mentioned a recovery disc...ahh i never liked brand name computers with preloaded software Never goes well when things go wrong
Best of Luck
RellikZephyr
    Self Build
    Intel Core 2 Duo E6850
    Asus P5K
    4GB Geil DDR2 PC2-6400
    ATI Radeon HD 2900XT
    Bose Companion 5 Speakers
    Asus 24" + HP 17"
    Seagate 500G SATA 7200RPM X 3
    Thermaltake Truepower 850W
    Thermaltake Kandalf LCS
    Liquid Cooling (Kandalf)
    Logitech G5
    Logitech G15
    ADSL 8Mb
To boot to your Vista disc, you'll need to go into the Bios and set the Optical Drive to be bootable. On start/restart you'll have a few seconds to hit any key in order to boot from the DVD.
    Proudly Built by Me!
    Intel Q6600
    DFI UT LP P35 T2R
    8GB OCZ Reaper DDR2 800 C44GK 4-4-4-12 2T
    Sapphire Radeon 4870x2
    AuzenTech Prelude 7.1
    1 Acer P243 24" and 1 Samsung T260 26" Monitor/HDTV
    Both are running at 19x12
    Seagate 1TB 7200.11 (Vista x64) Seagate 500GB 7200.11 (Win 7 x64)
    OCZ GameXtream 900w
    FSB at 400 (1600) Mhz, CPU Multi @ 8 for 3.2Ghz
and if thet doesnt work...
probably the best place to download a copy is from a torrent site
EDITED [z3r010] - REMOVED LINK (Thats my ass covered)
but you will need a torrent downloader program for it
the one i use is Azureus Azureus : Java BitTorrent Client
that should help
RellikZephyr
P.S
i dont condone downloading and using illegal copies of microsoft products... there my ass is covered
P.S.S
because i really dont care cause the amount of money microsoft makes a year, i think they should sell vista for $50
    Self Build
    Asus P5K
    Asus 24" + HP 17"
    Logitech G5
    Logitech G15
    ADSL 8Mb
