help me for VGA
Jrak
hello
my computer is VGA NIVIDA 5200 working for Acer AL1916W
but problem small fonts for 1440×900 pixles
need help me :cry:
    intel core 2 duo E7300 @ 2.66 GHZ
    intel G35
    4 GB DDRam 2
    sata 500 GB
It's just that card most likely can't support that resolution. Just bring it down a bit to a lower widescreen resolution.
Nevermind, I couldn't see the screenshot clearly before, though it looks fine to me atm.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Hi Jrak,
Comparing your screenshot with my screen, both at the same resolution, I cannot see any difference in font sizes. However, to increase the font size you need to change the DPI. Right click on the desktop and select 'Personalize'. On the left hand side of the screen that appears you will see 'Adjust font size (DPI)'. Click on this, and after providing administrative credentials, the following screen will appear.
You can select 'Larger scale (120 DPI) - make text more readable' and then click 'OK'. Any changes will take effect when you restart your PC. Should this be too large, or not large enough, you can click on 'Custom DPI...' to bring up the following screen (actually appears on top of previous screen).
Here you can either use the drop-down box to select a value or drag the ruler. You can even type a value directly into the box. Click 'OK' twice to close the dialogue boxes. Again, changes will take effect the next time you restart your PC.
Note that you may have to use large icons - right click on the desktop, highlight 'View' and select 'Large Icons'.
Dwarf
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
look the images founts acer AL1916W the pixles 1024×768
ned help me :cry:
    intel G35
    4 GB DDRam 2
    sata 500 GB
    ASUS Xonar DX
    100Mbps
i really don't see what the problem is here :confused:
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
Jrak - we need your question to be *specific* and concise - what exactly is the problem? I am not seeing a problem in either picture you posted, and I warrant that neither is anyone else....
The forums are not a race against time or a race to the finish to try to post your problem in as little words as possible - in fact, quite the opposite - you need to post as much detail as possible, including a detailed explanation of your problem, how it is replicable, etc.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
The problem that I suffer from it when I put this on the screen size 1440 × 900 and I'm sitting to see the screen size is very small, which affects the eye is for this reason I want to know whether the problem problem in the VGA-screen or in the screen itself and VGA screen NIVIDA 5200
    intel G35
    4 GB DDRam 2
    sata 500 GB
OK, so did you follow the advice given by Dwarf in the third post?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Do you have been in vain tried my Climate VGA screen??
    intel G35
    4 GB DDRam 2
    sata 500 GB
No offense, but that post makes very little sense - I suspect you are not an English speaking person, and there is nothing wrong with that - but the translation may make perfect sense to you but it does not here.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Change VGA on mycomputer ??
    intel G35
    4 GB DDRam 2
    sata 500 GB
Hi Jrak,
Your graphics card supports the native resolution of your display, and I would leave that as it is. A TFT/LCD display always works best and gives the clearest image when it is working at its native resolution. You may like to see if changing any settings in the 'Ease of Access Center' helps. Click on the start orb, type 'Ease of Access Center' into the search box and press enter/return. Click on 'Make the computer easier to see' and try the available settings. You will have to experiment a bit to find a combination of adjustments that suits you.
Dwarf
    Gigabyte IF233
