Help identify minidump files
slimkm
i need help identifying these 2 BSOD..
the one named sc 2 crash crashes when i was playing sc2
other one happens when i was just normal browsing using firefox and with vlc player on
system is Acer Aspire 5680
Vista 32 home premium SP2
Intel C2D T5600 1.83GHz each
2gb ram
Laptop age about 4-5years
installed from original vista cd but it's from asus
The first blames a hardware error while using your USB modem.
The other also blames hardware.
I'd suggest replacing the modem drivers first.
Also, please remove or update these older drivers that were loaded at the time of the crash. Don't use Windows Update or the Update drivers function of Device Manager.
Please use the following instructions to locate the most currently available drivers to replace the one's that you uninstall OR remove:
How To Find Drivers:
- I have listed links to most of the drivers in the code box below. Please use the links there to see what info I've found about those drivers.
- search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
- - The most common drivers are listed on this page: Driver Reference
- - Driver manufacturer links are on this page: http://www.carrona.org/drvrdown.html
Here's the older drivers (You can look them up here: Driver Reference ).
Please pay particular attention to any dated 2008 or earlier:
Code:
[font=lucida console]
b57nd60x.sys Mon Feb 26 17:50:32 2007 (45E36438)
 - Broadcom NetXtreme Gigabit Ethernet NDIS6.0 Driver
 - [url=http://www.carrona.org/dvrref.html#b57nd60x.sys]Driver Reference[/url]
EMS7SK.sys   Wed Oct 25 02:36:34 2006 (453F05F2)
 - ENE PCI Memory Stick Card Reader Driver
 - [url=http://www.carrona.org/dvrref.html#EMS7SK.sys]Driver Reference[/url]
ESM7SK.sys   Wed Oct 25 02:36:42 2006 (453F05FA)
 - ENE PCI SmartMedia / XD Card Reader Driver
  - [url=http://www.carrona.org/dvrref.html#ESM7SK.sys]Driver Reference[/url]
DKbFltr.sys  Thu Oct 19 04:24:28 2006 (4537363C)
 - Dritek Keyboard Filter driver
  - [url=http://www.carrona.org/dvrref.html#DKbFltr.sys]Driver Reference[/url]
SynTP.sys    Mon Oct 23 13:52:26 2006 (453D015A)
 - Synaptics TouchPad driver
  - [url=http://www.carrona.org/dvrref.html#SynTP.sys]Driver Reference[/url]
SMSCirda.sys Wed Apr 25 09:32:41 2007 (462F5879)
 - SMSC Fast Infrared Driver
  - [url=http://www.carrona.org/dvrref.html#SMSCirda.sys]Driver Reference[/url]
ESD7SK.sys   Wed Oct 25 02:36:47 2006 (453F05FF)
 - ENE PCI Secure Digital / MMC Card Reader
  - [url=http://www.carrona.org/dvrref.html#ESD7SK.sys]Driver Reference[/url]
NETw5v32.sys Mon Nov 17 10:40:18 2008 (49219062)
 - Intel Wireless WiFi Link Driver
  - [url=http://www.carrona.org/dvrref.html#NETw5v32.sys]Driver Reference[/url]
VSTAZL3.SYS  Tue Jun 20 13:39:49 2006 (449832E5)
 - Conexant Conexant SoftK56 Modem
  - [url=http://www.carrona.org/dvrref.html#VSTAZL3.SYS]Driver Reference[/url]
VSTDPV3.SYS  Tue Jun 20 13:41:01 2006 (4498332D)
  - [url=http://www.carrona.org/dvrref.html#VSTDPV3.SYS]Driver Reference[/url]
RTKVHDA.sys  Thu Mar 01 03:20:58 2007 (45E68CEA)
 - Realtek HD Audio Codec Driver
  - [url=http://www.carrona.org/dvrref.html#RTKVHDA.sys]Driver Reference[/url]
VSTCNXT3.SYS Tue Jun 20 13:39:37 2006 (449832D9)
  - [url=http://www.carrona.org/dvrref.html#VSTCNXT3.SYS]Driver Reference[/url]
lv321av.sys  Tue Nov 28 21:08:09 2006 (456CEB89)
 - USB Camera Driver                              - Acer OrbiCam                               - Logitech
  - [url=http://www.carrona.org/dvrref.html#lv321av.sys]Driver Reference[/url]
Amfilter.sys Mon May 14 17:38:21 2007 (4648D6CD)
 - [SIZE=2]A4Tech iWheelWorks Mouse Filter Driver[/SIZE]
  - [url=http://www.carrona.org/dvrref.html#Amfilter.sys]Driver Reference[/url]
LVMVDrv.sys  Tue Nov 28 20:55:40 2006 (456CE89C)
 -                               Logitech QuickCam Machine Vision Engine Loader
  - [url=http://www.carrona.org/dvrref.html#LVMVDrv.sys]Driver Reference[/url]
DPortIO.sys  Fri Dec 23 03:13:04 2005 (43ABB190)
 - Dritek Port I/O Driver
  - [url=http://www.carrona.org/dvrref.html#DPortIO.sys]Driver Reference[/url]
mdmxsdk.sys  Mon Jun 19 17:26:59 2006 (449716A3)
  - [url=http://www.carrona.org/dvrref.html#mdmxsdk.sys]Driver Reference[/url]
xaudio.sys   Fri Aug 04 20:39:09 2006 (44D3E8AD)
  - [url=http://www.carrona.org/dvrref.html#xaudio.sys]Driver Reference[/url]
qcusbser.sys Tue Sep 02 21:11:01 2008 (48BDE425)
 - QUALCOMM USB Modem/Serial Device Driver
  - [url=http://www.carrona.org/dvrref.html#qcusbser.sys]Driver Reference[/url]
[/font]
If that doesn't fix things, then I'd have to try replacing the USB modem to see if that helps. BUT, before you go to that expense, please run Driver Verifier according to these instructions:
Using Driver Verifier is an iffy proposition. Most times it'll crash and it'll tell you what the driver is. But sometimes it'll crash and won't tell you the driver. Other times it'll crash before you can log in to Windows. If you can't get to Safe Mode, then you'll have to resort to offline editing of the registry to disable Driver Verifier.
So, I'd suggest that you first backup your stuff and then make sure you've got access to another computer so you can contact us if problems arise. Then make a System Restore point (so you can restore the system using the Vista/Win7 Startup Repair feature).
Then, here's the procedure:
- Go to Start and type in "verifier" (without the quotes) and press Enter
- Select "Create custom settings (for code developers)" and click "Next"
- Select "Select individual settings from a full list" and click "Next"
- Select everything EXCEPT FOR "Low Resource Simulation" and click "Next"
NOTE: You can use Low Resource Simulation if you'd like. From my limited experimentation it makes the BSOD's come faster.
- Select "Select driver names from a list" and click "Next"
Then select all drivers NOT provided by Microsoft and click "Next"
- Select "Finish" on the next page.
Reboot the system and wait for it to crash to the Blue Screen. Continue to use your system normally, and if you know what causes the crash, do that repeatedly. The objective here is to get the system to crash because Driver Verifier is stressing the drivers out. If it doesn't crash for you, then let it run for at least 36 hours of continuous operation (an estimate on my part).
Reboot into Windows (after the crash) and turn off Driver Verifier by going back in and selecting "Delete existing settings" on the first page, then locate and zip up the memory dump file and upload it with your next post.
If you can't get into Windows because it crashes too soon, try it in Safe Mode.
If you can't get into Safe Mode, try using System Restore from your installation DVD to set the system back to the previous restore point that you created.
If that doesn't work, post back and we'll have to see about fixing the registry entry off-line:
Code:
Delete these registry keys (works in XP, Vista, Win7):
        HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\VerifyDrivers
        HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\VerifyDriverLevel
More info on this at this link: Using Driver Verifier to identify issues with Windows drivers for advanced users
BSOD BUGCHECK SUMMARY
Code:
Built by: 6002.18267.x86fre.vistasp2_gdr.100608-0458
Debug session time: Mon Oct 18 02:29:28.419 2010 (UTC - 4:00)
System Uptime: 0 days 6:32:30.272
Probably caused by : hardware ( win32k!HMValidateHandleNoSecure+2d )
BUGCHECK_STR:  0x7f_0
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
PROCESS_NAME:  HSPA USB MODEM.
Bugcheck code 0000007F
Arguments 00000000 00000000 00000000 00000000
Debug session time: Sat Oct 16 23:34:13.245 2010 (UTC - 4:00)
System Uptime: 0 days 0:24:34.071
Probably caused by : hardware ( nt!NtQuerySystemInformation+4d )
BUGCHECK_STR:  0x50
PROCESS_NAME:  svchost.exe
Bugcheck code 00000050
Arguments ffffff8b 00000000 8246ade6 00000000
  [/font]
Thank you for the info, i will try it after my coming exams and will let you know the results
as for the "dated 2008 or earlier" does it means that i need to update those drivers? and the list of drivers are from my laptop system?
Yes, the list of drivers is a list of those from earlier than 2008.
These drivers were present in the crash dump, indicating that they were loaded on your system when these crashes occurred. And, they are simply a list of the drivers dated 2008 and earlier from all the memory dumps that you uploaded. You can view the individual drivers in each memory dump using the lmtn command in the Windows Debugging Tools.
And yes, they should be updated.
But, there are a couple of caveats about this:
- there may not be updates available for some of the drivers
- the older drivers aren't necessarily the cause of the issue. But, they can be affecting things without our knowledge so replacing them is a good idea.
