Hy all , im new to this forum and i would need your help , btw sorry for my english.
So i purchased a NEW laptop , a GATEWAY FX7809U , it came with a sweet Windows Vista Sp1 , everything went fine for like an hour , but after an hr i got the BSOD , i was disparate what to do , i didnt know what to do and i installed windows 7 ,and that to Bsod , and the main problem , in windows 7 there was a lot of random BSOD , i mean bsod-s like :IRQL_NOT_LESS_OR_EQUAL after that PFN_LIST_CORRUPT ,SYSTEM_SERVICE_EXCEPTION ,etc , im not joking i had thease errors , so i started chdsk utility , found no errors , after that i ran some memmory test in windows 7 , found still no errors , i played games like GTA 4 with full details and no errors , i did all the tests and i was dissapointed i didnt find anything , and after that i sayd : This isn`t a hardware failiura , its software DUHH , after that i reinstalled windows Vista with no SP this time , and installed a drivers for the laptop and programs , it went all ok untill i restarted the laptop , again BSOD , i wanted to shoot my self this time :| i swear , i was with no ideas anymore , untill i sayd i will use MEMTEST86 cose everyone uses it and it gives satisfying results , the test started , it went to " Pass 28" after that 2555 errors found , it went to "Pass 39" it found totall 3831 errors , and believe me i was extreamly happy , not because the errors , because i found the major problem of the laptop , the problem was random bsods , every 5 minits i got a bsod , but enough of the talk , i need some special advice what to do , my laptop has 2 years warranty , and i found that the rams have errors , what should i do? Should i take it back from where i bought it ???
MY LAPTOP SPECS :
Intel Core 2 Duo P8700 1066 fsb 2.53 GHZ
4096MB 1066MHz DDR3 Dual Channel Memory (2-2048MB modules)
500GB 5400RPM SATA hard drive
Chassis with NVIDIA® GeForce® 9800M GTS Graphics with 1GB of GDDR3 Discrete Video Memory and Intel® PM45 Chipse
Intel® WiFi Link 5100AGN 802.11a/g/Draft-N Wireless LAN
Now please some 1 write here and tell me what to do , should i take the laptop back because its in warranty and they will fix it or what ???
MY LAPTOP SPECS :
- Gateway FX series 7809U
- Intel Core 2 Duo P8700 Fsb 1066
- 4gb ddr3 Fsb 1066
- NVIDIA 9800GTX 1024 mb ddr 3 256 bit
- Conexant Hermosa HD Audio
- Laptop Lcd panel
- 1440x900 17" laptop panel
- 1x SSD Kingsone hyperX 120 GB
- PSU
- 9 Cell battery with 7800 MAH
- 100 mbit/sec (megabit)
cose 1st i ran memtest and it had 3831 errors , i ran it second time it gave me only 2 erorrs , i ran it for 3 th time and no errors
