help for son
kev duncan
hi, ive just got a dell inspiron 1520 laptop and my son was asking if call of duty 4 would work on it, ive tried to look for the graphics card on the system but found that direct x 10 is installed but think that it only has a chipset card in it??
any ideas or help would be great.
    manufacturer-DIXONSXP,model-EI SYSTEMS 207
    430@ 1.80GHZ
    1.00GB
    INTEL 82945G EXPRESS CHIPSET FAMILY
    DESKTOP TOWER
    QUICK?
    NOT 100% COMPUTER LITERATE BUT WILLING TO TRY.
You could try it. If it runs good enough to play your set. If not...uninstall!
If it has the Core 2 Duo CPU and 2 gigs of RAM it just might. Specs say Integrated: ATI Radeon Xpress X1270 or Mobile Intel GMA X3100 or Discrete: Nvidia GeForce Go 8400M GS (128MB) or Nvidia GeForce Go 8600M GT (256MB).
If thats what you got you should be able to run it.
    My Ever Changing Whim!
    Intel Core 2 Quad 9650
    Intel DQ35JO
    6GB Corsair DDR2 800
    ASUS 9800GT Ultimate
    19 inch Sceptre 19 inch Acer
    1 320GB Seagate SATA 1 250GB Western Digital SATA 1 200GB Maxtor SATA 2x160GB Western Digitals SATA 1 320GB Seagate External 1 120GB Western Digital External 1 80GB Westen Digital External 1 4GB Crucial Flash Drive for Ready Boost
    600watt Fortron Source
    Antec
    Fresh Air
    Razer Diamondback
    Microsoft Natural Ergonamic 4000
    My main rig runs Vista Ultimate or Server 2008. Depending on which Acronis image I decide to load.
hi joel406,
a dont think mine haz 2gig ram.
it is the intel core 2 duo though and a think its 2 memory cards at 500 odds???
    430@ 1.80GHZ
    1.00GB
    DESKTOP TOWER
    QUICK?
Press and hold the Windows key on your keyboard and then press the "Pause/Break" key (it's on the same row as the F1-F12 keys, to the right above the arrow keys and Page Up/Down keys). This should bring up your System Properties window, if you're using Windows Vista you can just tell us what is listed under "Processor", "Memory (RAM)".
Windows Vista System Properties
Windows XP is a bit more complicated, just tell us what's listed under "Computer" section as seen below:
Windows XP System Properties
To find out what graphics card you have you need to go into your device manager, if you're using Windows Vista just click the "Device Manager" link near the top left of the System Properties window. If you're using Windows XP you need to click on the "Hardware" tab in the System Properties window, then click on "Device Manager".
Windows XP System Properties - Hardware Tab
Once you're in the Device Manger you need to expand the "Display Adapters" section, please let us know what is listed in "Display Adapters".
Windows XP Device Manager (it's the same in Windows Vista) - Display Adapters
Once we have the information (Processor, Memory, and Display Adapter) I've asked for we can determine if CoD4 will run on the computer in question.
    Acropolis
    Intel Core i7-6800k @ 4.0 GHz
    ASUS X99-M WS
    32GB Corsair Vengeance 2x16GB
    ASUS GeForce GTX 1080 STRIX
    ASUS ROG Swift PG278Q
    2x 256GB Samsung 850 Pro (RAID 0) 1x 500GB Samsung 850 Evo 2x Western Digital RED 4TB (RAID 1) 50TB File Server (Multiple RAID 6)
    Corsair AX1200i
    Corsair Air 240
    Logitech G502
    Razer Blackwidow X Chroma
    250Mbps Down | 15 Mbps Up
hi freelancer852,
listed in display adapters is- mobile intel 965 express family chipset.
system properties menu-
intel core 2 duo [email protected] ghz 1.50 ghz
1014 mb
32 bit operating system
base score is 4.0.
    430@ 1.80GHZ
    1.00GB
    DESKTOP TOWER
    QUICK?
kev duncan.
Sorry to say, with specs like that playing anything more then solitaire is pretty much out of the question.
You dont have the power to properly accelerate the games.
    Intel DQ35JO
    Antec
    Fresh Air
    Razer Diamondback
hi joel,
thanks for the reply, im not sure call of duty 4 will work but av got quake 4 loaded and playing no probs also car game grid they seem to be ok.
thank goodness coz a hate cards!!!ha ha
thanks anyway for all help.
    430@ 1.80GHZ
    1.00GB
    DESKTOP TOWER
    QUICK?
