Help for Error Code
buffaloes
Vista service pack two will not update i keep getting Error Code 80070081. Any help would be welcomed. Also i cannot update some of the windows updates
    Acer Aspire 9303WSMi
    Laptop
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
Disable UAC,Disabled Antivirus,Delete files in "%temp%", "temp", "prefetch" folder.Try to delete the pending.xml files if it's there, Reset IE.,Reset windows Update components.Perform clean boot,Download the Latest Version of Windows Update agent and install,Dowloaded Update SP manually.
It should work after these steps.
