help - Explorer crashing
tonyab72
Why does this keep crashing?
Problem signature:
Problem Event Name: APPCRASH
Application Name: iexplore.exe
Application Version: 7.0.6001.18248
Application Timestamp: 49f1c24f
Fault Module Name: ntdll.dll
Fault Module Version: 6.0.6001.18000
Fault Module Timestamp: 4791a7a6
Exception Code: c015000f
Exception Offset: 000763a2
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
:mad:
Application Name:iexplore.exe Looks like an Internet Explorer error.
    Compaq/SR5130NX
    AMD AthlonTM 64x2 3800+
    NVIDIA GeForce 6150 SE
Probably. Perhaps it is an isolated event and won't happen again.
Firefox is a free download. I've used it for years.
    Compaq/SR5130NX
I don't have any alternate golf games to recommend.:)
Ardneh
    Compaq/SR5130NX
You can try reinstalling it. That may or may not help. You can try upgrading to IE8.. .but don't try that just eyt.
I know sometimes you NEED IE to do things.For example tohere's a game that NEEDS IE to launch, not firefox, not Opra, IE.
Have you trid reinstalling it? When did this first start happening? Do you think restoring to an earlier date would help?
Go to Start and type in "iexplore -extoff" (without the quotes) and press Enter
This will launch Internet Explorer without the add-ons loaded.
Use this browser to surf to the places that usually give you this error.
If you don't get the error, then you can assume that it's one of your add-ons causing this.
To fix that, close that Internet Explorer and open one in the normal way. Then go to Tools...Manage Addons and disable them one-by-one until you find the one causing it.
