help display too big
mlewton
Everything on my screen including the screen saver and the explorer display has become too large for some reason. How do I get it back to normal please ?
It sounds like you just need to change your display settings.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
right click desktop select properties
select display settings
under the resolution tab select the correct resolution for your monitor then APPLY (or tell us what monitor you have and we'll tell you what res to select)
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Slide to right to change resolution.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
