HELP!! Automatically deleted my file
dhitman
Hello Forum's member.
I have a problem with window vista which automatically delete the file that I install. I try to turn of anti-virus and window defender and the vista still delete the file i download.
Is there a way not let the window do that?
Please reply.
Thank you
Hello and welcome to the forum.
First are you logged in as administrator, if not then you sholud not be allowed to download to the system...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    HP Multimedia Keyboard
    Microsoft Wireless Mouse 5000
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
I logged in as administrator. The problem is when i open the file or the program, it works for a min or so and then the file or the program got automatically deleted. I try to restart the computer and it still happen to me. The file or the program will not be deleted if i didn't open it.
Ok can you give me some more information about your computer.
1. Manufacture name...
2. Model Number...
3. Laptop or desktop..
Which program does this do it in or is it all of them, can you take a screenshot of what it is doing or write down what it says when it does it and then please post us back right away and see if we can fix it for you...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    Media Drive
Don't do anything else to your computer until we figure it out, we don't want something else to go wrong..
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    Media Drive
Manufacture name: Dell
Model Number: Inspiron I1720
Laptop - 32 bit
actually none of the file got deleted except application file.
Is a application name is called E3 (easy3game), is a game file so nothing actually happen to my computer because i can open other stuff such as Internet explore or other program fine. It just some how the system keep on deleting this file.
Ok how long has it been like this did it start today or a couple of days ago. Do you remember what you were doing when it first did this...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    Media Drive
Ok besides this have you checked to make sure it is compatiblie with Vista...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    Media Drive
It was 2 days ago, what happen is I open the file which is the application and it open so after a minute or so it close out of no where. So then I open the folder where the file locate and the application file disappear so I go take the application file from the Zip thing because the whole thing were compressed when I download the file. I use WinRAR, a program to unzip the file to get the application file out and put it back to the folder. Then I open it again and it did the same thing.
OK I think we are getting close, when did you install E3...
Have you installed anything in the last week or so...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    Media Drive
Ok lets do a system restore not a factory restore. To get your system back without losing any data, files, or documents.
A system restore means lets say you do a restore and go back 1 week, if you have not downloaded any software then you won't have to worry about anything I will give you a tutorial to help you through it, a system restore is very easy to do..
http://www.vistax64.com/tutorials/194765-system-recovery-options.html
http://www.vistax64.com/tutorials/76332-system-restore-point-create.html
After doing a system restore you will want to create a new one and this will tell you how.
Do Not put any disks in the computer you don't need them for just doing a system restore, so do one going back for 1 week before it started acting up and it should clear up your problem...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    Media Drive
