help about contrast
Click the buttons on the side of your monitor and explore around till you find the main menu.From there you should be able to find gamma,contrast,brightness etc etc.Hoe this helps.
    gateway
    intel quad
    8 gig
    nvidia
    realtek
    19' widescreen
    1440 x 900
    581 gb
    High speed Comcast cable
Hello jblim1980,
Good answer from blue75.
You can also do it from your video display control panel, there will be a section for the display so you can adjust and reset if you mess it up or go too far one way or another.
Good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Sorry , My bad by the way Im using laptop.. IL post a report from everest later
fill in yuor system specs and we'll tell yuo how to do it via your GPU drivers
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
I like the saying don't run you'll only die tired lolz ;)
    gateway
    intel quad
    8 gig
    nvidia
    realtek
    19' widescreen
    1440 x 900
    581 gb
