HELp a huge crysis
npm1
HELP PLEASE... uninsstalling software...not enough disk space...please free space
HELP PLEASE... uninsstalling software...not enough disk space...please free space http://www.vistax64.com/images/smilies/cry.gif
when i try to install software it comes up with (drive)not enough disk space..when i have 30gb left..
when i attempt to create a restore point twice 1st came up with 0x80070070 and 2nd was
when i load a picture it says not enough picture please close some apps/free up disk space
when i uninstall a software it says an error occured while writing installation information to disk.check to make sure enough disk space is available, and click retry or cancel end the ..
my computer has 1 harddrive split into C and D partitions...its an ACER 57357 with 4gb ram,2.16ghz-667mhz fsb-1mb l2 cache, 320gb harddrive, 4500m intergrated graphics
Post a snip of "Computer" so that we can see what the space situation is. 30GB free space may be not enough for some operations if that is less than 10% of the partition.
    Dell
    Q6600
    HP w2207h
Yes, e.g. via Photobucket.
    Dell
    Q6600
    HP w2207h
I though he needed help playing crysis
lol
    amd 64x2 4200+ 2.2ghz per core
    ECS NETTLE
    3 gb
    nvdia 6150se nforce 430(old rig, upgrading)
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    upgrading, Coolmax CA-450 450watts
    hp casing
    defult..
    hp
    hp
    768kbps down and 128 up...very slow..
    not great compared to other people..
