heeeeelp
ezzemad
command and conquer 3 doesn't work on my vista 64bit of my laptop but it works on the 32bit one of my disktop
is there any program or file can make it work ??
plzz anyone who have a previous experience with that problem please reply
People have successfully run CAC3 on Vista 64. Please make sure you have the latest video driver, SP2, and the latest CAC3 patch/installation.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
you can try by disabling your firewall...if that fails try reinstalling the game with the UAC turned off. then you will be fine.
I have it on my desktop 64 bit running fine ....a bit strange to hear that it wont work for you....for some of my older games i had to switch there compatability mode to do that just (1) right click game (2) properties (3) computability (4) choose your settings.
let me if this helps.
    HP pavilion entertainment pc DV4-1220us
    amd 2.1
    4 gb
    ati radeon HD 3200
    SATA 250gb 5400rpm
    15mbp
Remember to have the last drivers for your graphics card and turn off the UAC. A friend of mine had the same problem, it worked for him when he turned off the UAC and firewall.
    DELL Studio XPS 435T
    Intel Core i7 950 @ 3.07GHz
    6GB DDR3
    NVIDIA GeForce GTX 260 1792MB
    Soundblaster™ XFi™ Titanium PCI
    23 Inch Full HD
    1920x1080
    1GB Internal 2GB MyBook External 1GB MyBook External 500GB MyBook External
    Studio XPS 435T
    Logitech G5
    2MB
