headphone problems
jasond19
Power User
goodmoring vista. so im back on the toshiba laptop toshibaOperating System
MS Windows Vista Home Premium 32-bit SP2
Intel Pentium T2080 @ 1.73GHz 62 °C
Yonah 65nm Technology
RAM
1.0GB Dual-Channel DDR2 @ 266MHz (4-4-4-12)
TOSHIBA ISRAE (U2E1)
Graphics
Generic PnP Monitor @ 1440x900
Mobile Intel(R) 945 Express Chipset Family
117GB TOSHIBA TOSHIBA MK1237GSX ATA Device (SATA) 39 °C
Optical Drives
PIONEER DVD-RW DVR-K17LF ATA Device
Audio
High Definition Audio Device, im having problems with the headphones, il be playing a song, and then i plug in the headphones and the music still plays out of the computers speakers. i went to the speaker icon rite clicked and made sure it was turned up, and tested the headphones, all tested ok, got any ideas? ty
    toshiba satellite
    Intel Pentium T2080 @ 1.73GHz 66 °C Yonah 65nm Technology
    Generic PnP Monitor (1440x900@60Hz) Mobile Intel(R) 945 Expr
Re: headphone problms
Try to un-install your sound drivers and update them online once again. This problem normally appears when you are using Realtek sound drivers. With Soundmax audio drivers that are updated by default when you browse online your headphones would work perfectly right.
What you shud try if you are not using Soundmax as your default audio drivers:
1. Uninstall drivers present on your system and boot up your machine once more.
2. On next loggin make sure you are online as your vista will detect a foreign device and it will try to update it automatically.
3. If the above happens give it time to search for a correct drivers for your system.
    HP d530 SFF
    Intel p4 3.00ghz, 2.99ghz with Hyperthreading
    HP d530 SFF
    1 gb
    Intel i865g, 96mb
    Soundmax
    HP 1940 TFT monitor
    60hz
    Western Digital Cavier Blue 320gb IDE HD
    Compaq
    HP compaq
    HP Optical Mouse
    Techcom USB keyboard
    256kbs
ok,i tried that and still the same outcome. i cant understand why they are testing good, says everything is working proprly, but when i plug in the headphones nothing comes out, and the main speakers keep playing like i never pluged anything in, idk
    toshiba satellite
Hey Jason, welcome back.
As manyenya has mentioned above, realtek sounds like the audio device in question, do you have a control panel for the sound device? Not just the in-built windows application, but a secondary application to control tones and output settings?
This is where you would need to look, my audio device uses audio jack detection and when something is plugged in, it asks me what the device I plugged in is and sets it appropriately, you simply need to set the jack to auto-detect or set it manually to headset/headphones, hope this helps.
MrNeeds
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
mr needs id like to applgiz, the specs i posted were old, and some how reltk was unistalled dont know how, its my brothers computer, so i reinstalled reltk, and it work. again sry bout the out of date specs. i copyd and paste it from an older post when i was helping him with a probl, ty.
    toshiba satellite
It's ok, as long as the problem is sorted, you know where we are if you got anymore problems :)
Dave
    16Mb Sky bb
