I built my own HTPC last summer:
Zalman Case
ECS A780 GM-a motherboard
4 GB RAM
1.3 TB storage
It has worked fine, both audio and video, for months with my 62" Mitsubishi DLP TV through the HDMI connection on the motherboard. I bought a new Mitsubishi 73" (WD-73735) and I cannot get the audio to work (video is great 1080p). I have tried everything, driver update, OS update and I have tried every setting in the sound area in control panel. It shows everything is right, no mute, driver OK, HDMI sound is the default even shows a sound bar jump when I move the slider up and down.
I moved the 62" TV into another room so I disconnected the HTPC from the new TV and reconnected on the 62" TV, everything works (audio and video), move it back and no audio
It is obviously a problem between the ECS MB and the new TV. I know the new TV is HDMI 1.3 compliant but I assume it is also backward complient to all HDMI standards. All my other HDMI systems (cable, blu-ray, etc.) work on the new TV, just the HTPC has problems.
The video on the MB is ATI HD3200 and the audio is ITD, I updated both drivers to no avail.
Anyone have an idea why it doesn't work?
Thanks,
Clancy52
Zalman Case
4 GB RAM
1.3 TB storage
Thanks,
Clancy52
