I'm new to this site and also a new user of Windows Vista. I'm currently experiencing a problem with my non-vista HDD. In Vista Home Premium x86 (and only in Vista OS because I also have Windows XP and no problem there) every so often my 2nd HDD will disappear completely. That is, no detection of sorts and this happens after my PC has already been running for a while. I initially thought it might be a power supply issue but after playing around a little with my PC I found out that's not the case. I'm wondering if anyone might have any ideas about this. Oh, and also before my HDD dissapears the PC will make a noise very similar to the one you hear when it hangs (a beeping sound from the case).
I have a dual-OS custom built PC. Both OS are installed on 2 physically different SATA drives. My configuration is
1x Asus P4P800SE
1x P4 at 3.0Ghz
4x Kingston K-series PC3200
1x ATI Radeon X700 Pro
1x Sounblaster X-Fi
1x Seagate 120g ST3120026AS SATA (XP Drive and the one that dissapears)
1x Seagate 500g ST3500630AS SATA (Vista drive)
1x Windows Home Premium x86
1x Windows XP Professional SP2
Thank you for taking the time to look at this
P.S. Upgrading at this point is not an option unfortunately. Furthermore, sometimes the computer will go days or even weeks without a glitch.
1x Asus P4P800SE
1x P4 at 3.0Ghz
1x Sounblaster X-Fi
