HD Audio.exe bug
David3
Hello, my computer is showing that I have a drive A: when I dont. This has recently caused a bug that has a window popup saying a bunch of stuff about a drive beeing open, drive A: so i go and try to uninstall the drive but the window quits responding every time. Any other way to uninstall this drive??? Thanks
    Home Built
    Quad Core i7
    EVGA 750i SLI
    4 GB Crucial Ballistix Tracer 8500
    Nvidia GTX 465
    samsung flat
    SEAGATE 500 GB
    NVIDIA Case
    Blue Orb
    Microsoft Wireless
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
hi David, you can uninstall the drive by simply disabling the drive in the bios. The A:\ drive is referred to as a floppy drive and has probably been enabled by accident or other reason, i'll post a tutorial of how to do this in about 10 minutes.
MrNeeds
Edit:
here's the tutorial
first of all, I notice that you have an EVGA nforce motherboard so that means you'll have the same BIOS as myself, restart your PC and press Delete on the post screen, this will bring you to this screen:
select the standard CMOS features and hit return, you'll notice this screen with the suspect A drive:
just use your arrow keys to navigate to that option and select none in the list:
it should then look like this:
simply press escape now and select save and exit:
hope this helps :-)
MrNeeds
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
When you right click on computer and click manage,storage,disc management does it show up here.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
    Home Built
    Quad Core i7
    EVGA 750i SLI
    Nvidia GTX 465
    samsung flat
    SEAGATE 500 GB
    NVIDIA Case
    Blue Orb
    Microsoft Wireless
Perhaps I may have changed it by mistake, thank you.
    Home Built
    Quad Core i7
    EVGA 750i SLI
    Nvidia GTX 465
    samsung flat
    SEAGATE 500 GB
    NVIDIA Case
    Blue Orb
    Microsoft Wireless
Fixed:D
    Home Built
    Quad Core i7
    EVGA 750i SLI
    Nvidia GTX 465
    samsung flat
    SEAGATE 500 GB
    NVIDIA Case
    Blue Orb
    Microsoft Wireless
