You should upgrade or use an
alternative browser .
having problem installing itunes
hi guys any one can help me i tried installing itunes on my loptop vista home basic 32bit
but i cant install it, i tried using registry booster but still the same i tried installing new version of itunes and installing it though "run as administrator" but still the same, any one could help me?
here's the error im getting when i install itunes
Magister mundi sum!
Hi and welcome to the forum
This problem is with your PC and not with iTunes as you probably already know.
I suggest, though a tad drastic, a repair install.
This would patch, replace or add any missing system files that may need to be fixed including the program that is required for iTunes to install.
There is a tutorial on how to do this at
http://www.vistax64.com/tutorials/88236-repair-install-vista.html?ltr=R .
If you have any further questions do ask away.
Oli
Apple MacBook, 5,1
Intel Core 2 Duo 2.4Ghz
4GB DDR3
Nvidia 9400m
13.3" Apple MacBook LCD Screen + 22" HannsG DVI LCD + 21.5" Samsung USB Lapfit Monitor LD220
1280x800 + 1920x1080 + 1920x1080
SATA Internal 2.5" 500GB (305GB HFS+, 195GB NTFS)
External USB 3.5" 1TB (HFS+)
Aluminium Unibody
Apple Magic Mouse
Apple Late 2009 Wireless Keyboard (US)
6.33Mb/s up. 0.36Mb/s down.
Harman Kardon Soundsticks II Speakers
