Hardware acceleration and Direct X
Mindjakk
I could not find this post elsewhere, but I can't get my directdraw to enable or mess with my hardware acceleration.
Its just not active...any suggestions would be great.
Latest Drivers Wiped and reinstalled all around.
Regedit timeout is at 7
Nothing seems to change it, ANY suggestions would be great, thanks.
I downloaded and loaded the latest, and older, drivers from both Nvidia and EVGA, my card manufacturer. Non of which has fixed the issue. Everything reads fine, as to the correct versions, but it always remains with the same problems.
Are there some sort of special privileges that I am missing, or possibly an included program with my card that controls these functions instead of windows?
I have installed everything I can find from the Card Manufacturer and chip Manufacturer, I have updated my board bios to the latest and so on, but nothing seems to make ANY difference.
    Intel Core 2 Quad Q9550 Yorkfield 2.83GHz LGA 775 95W Quad-C
    GIGABYTE GA-EP45T-UD3LR LGA 775 Intel P45 ATX Intel
    CORSAIR XMS3 8GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
    EVGA 512-P3-N871-AR GeForce 9800 GTX+ 512MB 256-bit GDDR3
    On board
    KDS 2200W
    1680X1050
    2X Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 1X Western Digital Element 1TB 3.5" Black External Hard Drive
    PC Power & Cooling / Silencer / 750-Watt / Quad PCI-Express
    Cooler Master Centurion 5 - Silver ATX Mid-Tower Case
    Rosewill RCX-Z2 7 blades 80mm reverse ball bearing fan CPU
    Optical
    Innovations KB565BL
    Cable
dont worry about hardware acceleration you cant change it anyway , its a hardware thing its managed internally
i assume you tried...........
Download details: DirectX End-User Runtime
one more thing......do you have onboard graphics? did you disable them properly?
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Yep I downloaded and installed that DirectX, a couple of times just to be sure after i have done all the updates that I still had the latest versions of all the DirectX, Runtime, Redist., and Web versions.
No onbaord graphics card at all.
Thanks, I have been trying to get an answer from everywhere and nothing is working.
    On board
    KDS 2200W
    1680X1050
    Optical
    Innovations KB565BL
    Cable
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
