Firstly I'd like to say that I'm glad to be joining the site, you guys seem to be doing great job here!
Like I said, it's tricky to explain this properly, but I'll try anyway. Windows won't let me interact with different windows properly. Once a window is minimized it's next to impossible to access it again without using taskmanager - switch to. If I click on the window from the taskbar (if it had been minimized of I was viewing another window) it come up fullscreen as usual, but then I can't click on anything on the window, it's as if I'm clicking "behind" the window, no matter what I try.
Maybe a clearer way of describing it is that the only way I can change the active window is with task manager, items in the task bar can be switched in and out of view but not activated.
Also occasionally icons on the desktop are unresponsive. And I also forgot to say that sometimes the task bar is sometimes completely unresponsive.
Anyone have any ideas? If you have any questions it might help for me to describe it, as I don't really know what you're looking for in terms of figuring out the problem. I'd love to get this sorted as it's incredibly frustrating!
