ConsoleKing
I just switched to Vista (32Bit) and I have a question about my hard drives.
The main hard drive I'm using is a Western Digital 500GB Sata II. The hard drive works fine and has no problems.
My second and third hard drives are 2 x Hitachi 500GB Sata II. The problem is every 5-10 minutes they make the noise as if they are turning on even when I'm not accessing them. In XP this didn't happen, is this normal in Vista? I turned power options to high performance.
The Hitachi drives still work fine but I'm wondering why this noise happens? In XP this only happened when I turned on the PC.
Thanks in advance
Thanks in advance
