hard drive won't defrag
Dale.Try turning off some programs first.If that does not work,try Safe Mode.
Re boot your PC,then press F8 on your keyboard,before your system loads up.
    Intel Celeron 550 2.0Ghz
    1024MB DDR2-533MHz
    ATI Express 300M
    Sata 100GB Internal Seagate 500GB External Seagate 160GB External
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
All defraggers need to have enough free space on the drive, to be able to shuffle the files around. You could use Windows own disk cleaner or Ccleaner to make space by deleting stuff in the TEMP folder and temporary internet files (the browser's disk cache) etc.
It's best to run the defragmenter program soon after a reboot, before running any other programs.
There are some system files in use which cannot be moved while Windows is running. Some defragmenter programs include an option to do a "boot time defrag" which schedules a defrag for the next boot. It does the job before Windows is loaded, so it can defrag the system files. Or you could run SysInternals PageDefrag (which is specifically for difficult files such as the page file) before running your normal defragger in Windows.
PageDefrag
    home assembled
    Intel Q9450 quad core
    Asus P5Q Pro, Intel P45 chipset
    4GB : 2 x 2GB G.Skill DDR2 800MHz
    Gigabyte 9600GT
    Realtek onboard the mobo
    BenQ 24"
    1920 x 1200
    2 of Samsung HD501LJ SATA2 500GB and a few IDE hard disks on USB for backups
    Corsair TX-650 and APC UPS
    Antec P180
    OCZ Vendetta2
Hi Oldbloke,
I looked at page defrag before on sysinternals site, but never used it since it doesn't list Vista - just says this :
PageDefrag works on Windows NT 4.0, Windows 2000, Windows XP, and Server 2003.
Does it work on x64 Vista ? - if so, I'l give it a go.
Thanks
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Ooops, I didn't check it's compatability with Vista 64. Sorry about that. Last time I used it was in XP. I'm not sure whether you can safely use it in Vista 64.
One alternative is to install the free trial of PerfectDisk which has a boot time defrag option.
I notice Dale_N has the O&O defragger. I'm not familiar with it but I imagine that too has an option to do a boot time defrag of system files.
Whichever one you use of all those programs, all defraggers need enough free space on the target partition, to make it easier to rearrange the files.
    home assembled
    Gigabyte 9600GT
    BenQ 24"
    1920 x 1200
    Antec P180
    OCZ Vendetta2
