Hard drive too large?
oldun
I have a HP Pavilion TX1340 laptop running Vista Home Premium.
The laptop came with a 120GB hard drive and I would now like to replace it with a new 320GB hard drive which I have fitted in a USB2.0 caddy and which, after much difficulty, I have managed to initialize and format.
I have been told by HP that the laptop will only recognise hard drives up to 250GB.
If I partition the hard drive with a 250B partition plus another partition occupying the remainding space will this work OK?
Unfortunately, your only option is to send me the hard drive as it will not work for you. Sad but true; PM me for my home address.
;) just kidding... it will work fine. If it only sees the first 250, then partition and use that; format the rest in Windows.
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary 1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
hi oldun,
the 250G limit probably only applies to the internal drive, your usb caddy now controls the new drive so you should be able to use all 320 in 1 partition.
but it sounds like you currently have 1 partition as you have already formatted.
just plug it in and see if windows recognises the drive if so, you're done.
or just send the drive to fumz
cheers
    E8400
    asus p5ql-e
    ocz pc 1066 2x2gb
    asus eah3650 silent
    Edirol UA-25
    Gateway FPD2185W
    1680 x 1050
    750g samsung
    Zalman ZM460B 460W
    Lian Li A05 + 2 x Sythe S-FLEX SFF21D 120mm case fan
    Coolermaster Hyper Z600 fanless CPU cooler
    Microsoft Laser Mouse 6000
    Merc Stealth
    DSL
Geezer,
it sounds more like oldun wants to remove the 320 from the USB caddy and put it *physically* in the laptop - thereby running into that 250 GB Limit.
Oldun, if the BIOS can only access 250 GB you may not be able to see the rest of it in Vista - so be prepared.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
