Halo 2 Problems
Baaaax
Well, i've installed Halo 2 fine and everything, but when i play ingame for around 5-15 minutes, it'll randomly freeze, then turn my screen off, the only solution is to restart my computer :(
I also get a Blue Screen of death sometimes.
Any help would be appreciated
Computer specs:
Intel Quad Core 2.66Ghz Q6600
4GB Ram
GeForce 8600GT
Does this only happen in Halo 2? Does your computer have enough ventilation so as to not overheat? Have you overclocked your system? What does your BSOD say?
    E6750 @ 3.2GHz
    Asus P5K-e/Wifi-AP
    4x1GB Crucial Ballistix DDR2 800
    PNY 8800GT @ 675/1675/950
    Asus Xonar DX
    Samsung SyncMaster 220WM
    500GB WD SATA II 500GB Seagate SATA II
    700W OCZ GameXStream
    Cooler Master Centurion 5
    Arctic Cooling Freezer 7 Pro
    Logitech G5
    ~3Mb
Hi, Baaax, and welcome to the forums.
Which motherboard are you using, and have you tried removing 2 GB of RAM and seeing if it made a difference? Having all four memory slots populated puts an incredible strain on the Northbridge, and if it is not adequately cooled, even when not overclocked, it can still get blazing hot.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Thanks for the welcome.
I'm using a Gigabyte S-Series Mother board, i just tried it with 2 GB of ram, doesn't seem to make a diffrence.
Is your DirectX updated to the latest version? Are all your drivers up to the latest version? Are you using a WHQL driver for your video card or a modded one?
And whenever you get a chance at posting the BSOD, that'd be great.
    E6750 @ 3.2GHz
    Asus P5K-e/Wifi-AP
    Asus Xonar DX
    Logitech G5
    ~3Mb
It could be a RAM issue, a bad sector issue on your HD, a simple application error, or it could even be something a lot harder to trace. That BSOD error is going to be the critical key right now.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Ok, the only thing i could read on the BSOD before it flashed of and restarted was
" A problem has been detected, attempting to restart"
And i hope it's not a bad sectre on my HD, this computer is only around 2 months old.
Hey Bax,
There should be a window after you restart with details about the BSOD, it displays "Windows has recovered from a disruptive shutdown" and that box has the BSOD information, otherwise just turn off "automatic restart on failure" so it displays the error code ;)
Steven
  1. Hold the Windows key down and hit the Pause button (If you do not have a Pause button, or it is a special function key, as on some laptops, then you can go to Start --> Control Panel --> System and Maintenance --> System (If you are using the new CP interface) or Start --> Control Panel --> System (if you are using the classic interface)
  2. Click on Advanced Settings on the left
  3. Grant elevated privileges (click Continue on the UAC prompt)
  4. Make sure you're on the Advanced tab
  5. Under Startup and recovery click the Settings button
  6. Under System failure *uncheck* Automatically restart
  7. Click OK
  8. Click OK
  9. Close the System window.
Now when the BSOD occurs, it will not automatically reboot.
HTH
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
