Graphic card more speed ?
1intesity25
[Hi I play this online game where you have to be very fast to bid, but lately I haven't been doing so good anymore, because everybody is upgrading their connection speed and doing macros to play, a friend of mine told me she installed a graphic card, and her game speeded up considerably. is this true does a craphic card also makes your pc faster ???[/B]
    Dell xps 435 MT
    6 mbps
depends if your fps is under 30 you want your FPS to be above 30 constantly at 60 though your eyes cant see the differences . if not check your CPU and see if its at full load if thats not it check your ping its usually like a command in the game like /ping or there is a option on the game that shows u how many MS it takes to get to their server best connection possible is usually under 200ms, 250 can work too.
which game u playing btw? AION? WoW?
    Custom built Desktop
    AMD Phenom II X6 1090T Black Edition 3.2Ghz
    MSI 890FXA-GD70 AM3 AMD 890FX
    8GB Adata Gaming series 2.0 DDR3 1600
    MSI Twin Frozr 5830 X2 with MSI 5850 Crossfired
    Asus 19", Acer 17"
    1400x900
    OCZ Agility 3 60gb, 500GB F3 Samsung Spin point and 5 other HDD's
    850W OCZ
    NZXT Phantom
    2 200mm fans with 6 120mm fans
    Logitec G9
    Saitek 2
    Major AMD, ATI and MSI Enthusiast.
I'm Sorry I don't really know what fps means, I wish i knew more abouth computers and hardware, but it is what it is, but I'm a good learner : )
the game is called pets, at the www.tagged.com site
    Dell xps 435 MT
    6 mbps
FPS = Frames per second , MS = Milla seconds basicaly .001 of a second
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
hm..... should be somewhere in a corner, if not you can prolly find it in the game menu
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
if thats above 30FPS constantly ur good to go bro, just make sure your latency is good aka MS connect to the server
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
