graphic card for laptop
chinu89
is there is any graphic card for laptop? i buys a laptop in which here is no graphic card but now i want to installed a graphic card in my laptop so what can i do?
    HCL
    Intel(R) Pentium(R) Dual CPU T2330 @ 1.60GHz
    2GB RAM
    160 GB sata
    BIOS=101/102 key Keyboard=AT-MF2 : 8
Hi chinu89,
I need the full manufacturer, make, and precise and complete model number of your laptop to see if I can check online. The info in system specs is nowhere near to the level of detail I need. Whether or not possible depends entirely on the computer. Some are built into the motherboard and others use a slot - and the type of slot varies if that's how it is done - the latter can sometimes be changed depending on other factors which may limit choices (like the power supply, the type and number of slots,...). If you can provide a link to the manufacturer's webpage for your specific computer, that would be a big help. Then we'll see where we can go from there if they include that level of detail.
Thanks and good luck!
    1920 x 1200 pixels
Your system specs should be filled out in more detail, so that we may be able to help you with future problems. In addition each computer owner should know as much as possible about his computer. Download and use this software to help provide you with the necessary information. In addition, it will give you temperature information that may help prevent problems.
Speccy - System Information - Free Download
HCL Notebook k 28
model No. AXOK2810
    HCL
    2GB RAM
    160 GB sata
Thanks! I have a doctor's appointment and then some chores, so it may be a bit before I can get back to you - unless someone else does so in the meantime.
I'll respond as soon as I've finished and had time to research it.
Take care!
    1920 x 1200 pixels
unfortunately chinu, I have some bad news, your Graphics Card is an onboard one which is soldered, there may have been a chance if your graphics card wasn't intergrated but simply put, changing the graphics card would cost more than the laptop itself, i think your only solution could be to buy an external graphics card dock and use the express card slot to power it which you have, you would need to buy any graphics card as long as its PCI-E x16, look here Village Instruments : ViDock
hope this helps
MrNeeds
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Please fill out system specs, so that we can give you all the help that is needed in the future, if any is needed.
Yes most laptops dont have replaceable graphics cards. Thats why games use desktops. Besides you dont really need a powerful one except for video editing and games. My laptop uses intergrated just fine.
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6 Thomson A/B/G/N Router LiteON CD/DVD Player GAME PERFORMANCE: Battlefield 3: 41 FPS High 1x AA @ 1280x720 Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080 Counter Strike Source (and other Valve games): 300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
ok thanks who gave their important advices . i made a big mistake by buying a laptop without a graphics card so if somebody wants to play heavy requirements games like race driver grid please don't repeat my mistakes take care of it.
    HCL
    2GB RAM
    160 GB sata
No problem, here to help
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
