Having random BSOD's. Have tried cleaning interior and removed dust. Reseated peripherals. Have tried analyzing using debugging sw (which is brand new for me). But, the output is not telling me what I need to do to repair. Moreover, I can't seem to successfulyy dl symbols. Here is the output (as well a zipped file with more info, as per the instructions of this forum regarding posting queries for BSOD's):
WARNING: Whitespace at end of path element
![mad :mad: :mad:](/images/smilies/099.gif)
Code:
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: .sympath[+] srv*c:\symbolfiles*[URL="http://msdl.microsoft.com/download/symbols"]Symbol information[/URL]
;.sympath[+] srv*C:/symbolfiles*[URL="http://msdl.microsoft.com/download/symbols"]Symbol information[/URL]
Executable search path is:
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntkrnlmp.exe -
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x64
Built by: 6002.18267.amd64fre.vistasp2_gdr.100608-0458
Machine Name:
Kernel base = 0xfffff800`02646000 PsLoadedModuleList = 0xfffff800`0280add0
Debug session time: Thu Oct 14 08:41:55.354 2010 (UTC - 4:00)
System Uptime: 0 days 5:53:16.170
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 000007ff`fffdb018). Type ".hh dbgerr001" for details
Loading unloaded module list
* Bugcheck Analysis *
BugCheck A, {fffffd5ef03c8160, 2, 1, fffff800026ba78f}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Page 8037a not present in the dump file. Type ".hh dbgerr004" for details
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : ntkrnlmp.exe ( nt!PsGetCurrentProcess+40ff )
Followup: MachineOwner
1: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffffd5ef03c8160, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff800026ba78f, address which referenced memory
Debugging Details:
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
MODULE_NAME: nt
FAULTING_MODULE: fffff80002646000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4c0e5ae3
WRITE_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get nt!MmPoolCodeStart
unable to get nt!MmPoolCodeEnd
fffffd5ef03c8160
CURRENT_IRQL: 0
FAULTING_IP:
fffff800`026ba78f 498160201ffcffff and qword ptr [r8+20h],0FFFFFFFFFFFFFC1Fh
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xA
LAST_CONTROL_TRANSFER: from fffff800026a026e to fffff800026a04d0
STACK_TEXT:
fffffa60`08f5f298 fffff800`026a026e : 00000000`0000000a fffffd5e`f03c8160 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffffa60`08f5f2a0 fffff800`0269f14b : 00000000`00000001 00000000`0001007c fffff900`c09a6a70 fffff680`0003fd88 : nt!ZwUnloadKeyEx+0x23ce
fffffa60`08f5f3e0 fffff800`026ba78f : 000003a1`000003ae 000003c0`00000486 00000000`00010088 00000000`00000440 : nt!ZwUnloadKeyEx+0x12ab
fffffa60`08f5f570 fffff800`026b6c16 : 00000000`00000000 fffff960`000beb2e fffff900`c0c05ef0 fffff900`c0c05ef0 : nt!PsGetCurrentProcess+0x40ff
fffffa60`08f5f5a0 fffff800`0269f059 : 00000000`00000000 fffffa60`08f5f648 00000000`07fb1401 00000000`03497da0 : nt!PsGetCurrentProcess+0x586
fffffa60`08f5f680 000007fe`fc265124 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!ZwUnloadKeyEx+0x11b9
00000000`0389e880 fffff800`0269a0c0 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7fe`fc265124
fffffa60`08f5fa60 fffff900`c0936450 : fffff900`00000000 00000000`00000000 fffff960`0011bbaf 00000000`00040000 : nt!KiCpuId+0x30
fffffa60`08f5fa68 fffff900`00000000 : 00000000`00000000 fffff960`0011bbaf 00000000`00040000 fffffa60`08f600e0 : 0xfffff900`c0936450
fffffa60`08f5fa70 00000000`00000000 : fffff960`0011bbaf 00000000`00040000 fffffa60`08f600e0 00000000`00000000 : 0xfffff900`00000000
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!PsGetCurrentProcess+40ff
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ntkrnlmp.exe
BUCKET_ID: WRONG_SYMBOLS
- Dell
- 2.80 gigahertz Intel Core2 Duo
- Dell Inc. 0RY007 A01
- 4086 Megabytes Usable Installed Memory
- NVIDIA GeForce FX 5200 Intel(R) G33/G31 Ex
- Realtek High Definition Audio
- Acer V173 NEC LCD72V
- ST3750630AS [Hard drive] (750.16 GB)
