Geforce 9600GT stops working why
Try backing down your OC until it stops that error.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
730 1825 955 stable thats when its stable>.>
core shader memorey
But why would it not work after OC it more that on Call of duty World at war
As the card works harder and is required to do more it overheats and becomes unstable. The reason it fails earlier while playing certain games is related to the intensity of the graphics and the amount of work it is doing. You should be aware that if you continue to over clock to the level you are you will probably be looking for a new card very soon.
Norm
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
yeah but its only at 50c when playing a game
The sort of stable overclock you are going to get with a 9600GT is going to be so little you aren't going to notice much difference. The highest stable clock I've seen was 750/1900/2000.
Norm
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
@ Shawn4455,
NormCameron is right on all accounts.
Certain games can handle higher OC cards then others. When I was OC'ing my ATI HD3870, FEAR would crash, while Half-Life 2 - EP2 would run fine at the same OC setting. And to be honest, I wound up RMAing that card as I probably pushed it a little to hard. Based on your problem, you will definitely be looking for a new video card if you continue pushing it...the card is already giving you warning signs. I'm all for overclocking...done in moderation. Your card, your money, so...
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
wait one question this is my card Newegg.com - PNY VCG96512GXEB GeForce 9600 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Desktop Graphics / Video Cards
and rivatuner is reading 650 1625 900
core shader mem clock
why o.o or am i reading it wrong what do you think is a safe over clock o.o
This is not a high performance card, and there is no way you can make into one. Overclocking reduces the life of the card. To get better performance on Games you need to lower the in-game settings, or screen resolution. Although you say your card runs at 50c this is normal. Under load it is going beyond 80c, which is why it freezes or crashes. At the very least you need to install a third party cooler, and you won't be able to clock more than about 10% over specs anyway. This is not sufficient improvement to warrant "bricking" your card.
You need to learn to live with it or upgrade your card.
Norm
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
I would suggest you visit one of the Nvidia forums to find out what your card can do, or at least its limitations. They could also tell you what the best OC solution is, if any.
Good luck
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
There's a girl who hangs around on the SLI forums who overclocks a lot, not serious overclocking. She overclocked two 9600GTs in SLI and they benched the same as two 8800 Ultras in SLI.
Though the majority of cards can't really be seriously overclocked without a few modifications.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
