Gateway is no help for Moniter driver
dtholm
I e-mailed Gateway and send the my Vista (32 bit) is showing a non plug and play monitor and I wanted to update the driver because I have a PNP 19" Wide LCD Flat Paner Monitor (the system is not Gateway) They e-mailed me back and told me to down load EZTTune. In the EZTune readme "EzTune is not a monitor driver. The correct driver for Gateway monitors is the Generic plug and Play driver." So Where can I download it from please post or
send a link to me. Thank You
Don
EMAIL ADDRESS REMOVED BY: Brink
Generic Plug and Play monitor driver is built into Vista - however, if Vista is not recognizing it as a plug and play monitor, there may be something going on - something as simple as Plug and Play being turned off, to something more complex, such as Gateway using a specialized plug on their monitors that interfaces with its video cards differently than it does with standard video cards....
Try manually changing the driver to generic monitor in Device Manager and see what happens....
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
John, In the device manager under monitor it only list the Non PnP also. it also only shows non PnP drivers a line or two down.
under the action tap I scanned for new hardware no change.
how and where in the device manger do I change the monitor driver or turn on the plug and play?
