Game FPS significantly lower after mass system upgrade
ktstowell
Heyas all,
After my local PC store has proven themselves noobs, i've decided to peruse some forums for a resolution to my dilemma. For 2 years until a week ago, this was my system:
AMD 4200+ Athlon x2 2.8GHz
Geforece 9500GT 128 bit, 1GB DDR2 32 strm proc. (this was my latest card)
3 GB of DDR, 3 sticks at PC 3200 and one at 2700 ( retarded i know, but wait)
Xtreme sound 5.1 Daimond MM cheapo speacial
MSI 7185 nForce 4 mobo, SLI etc..
After fate took its toll and i fried my cpu from a tiny shaving of metal from my drill bit head after installing a new fan, i was in a pinch for time and went and bought a new system:
( from dxdiag with my own notes):
System Information
Time of this report: 8/3/2009, 17:02:21
Machine name: KENNETH-PC
Operating System: Windows Vista™ Ultimate Service Pack 1
Language: English (Regional Setting: English)
System Manufacturer: MICRO-STAR INTERNATIONAL CO.,LTD
System Model: MS-7511
BIOS: Default System BIOS
Processor: AMD Athlon(tm) 7850 Dual-Core Processor (2 CPUs), ~2.8GHz
Memory: 4094MB RAM ( super talent ddr2 pc6400 800)
Page File: 1221MB used, 7145MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 10
DX Setup Parameters: Not found
DxDiag Version: 6.00.6001.18000 64bit Unicode
Display Devices
Card name: NVIDIA GeForce 9500 GT
Manufacturer: NVIDIA
Chip type: GeForce 9500 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0640&SUBSYS_094319F1&REV_A1
Display Memory: 2799 MB
Dedicated Memory: 1007 MB
Shared Memory: 1791 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor: Generic PnP Monitor
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver Version: 8.15.0011.9038 (English)
DDI Version: 10
Driver Attributes: Final Retail
Driver Date/Size: 7/14/2009 11:54:00, 9375232 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-4500-11CF-0F59-482901C2C535}
Vendor ID: 0x10DE
Device ID: 0x0640
SubSys ID: 0x094319F1
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
THE QUESTION IS:
even after a significant system upgrade why am i only getting 8-16 FPS on my games when before i even had ram w/ different timings!
i've scoured my event log, driver version and updated my bios. Ive ran memtest86 and chkdsk and every other utility, i really am at a loss and need help.
any and all advice is uber appreciated.
(and yes i've spoken with tech support from my games and they don't know what it is either)
thank you
ktstowell
Did you reset your bios when you did all this upgrade? what about your hard drive, did you install a fresh vista? Sorry, you either didn't specify all this or I am getting more senile by the minute. ;)
Also, I am terrible at reading DXdiag specs... did you also updated your motherboard?
You may want to go to your profile and update your "System Specs", this way, we all can see them and help better. You can see mine at the bottom of the content window above the Orange Post Reply button.
8-16 FPS increase is huge (believe it or not), more so if the other video settings went from low to high or even med to high
What did you use to measure the FPSs?
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
I would check you BIOS as AstaLaVista suggested. You can optimize the computer memory, etc. As far as DX10, you also have DX9 installed as well.
Lastly, what game are you playing that the FPS stinks?
    Cyberpower
    AMD Phenom X4 9850
    MSI K9N SLI V2
    8 GIG DDR 800
    EVGA 9800 GT 512mb
    onboard
    SyncMaster 220wm
    Hitachi something or other 500 gigs
    650 watts
That graphics card needs to be updated. A 9500GT is at the bottom end of gaming cards. A 9800GT would be a worthwhile update. It won't be your system, the cpu is OK, the memory is enough, but the gpu is slowing things down.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
