Flight Sim X/DirectX Installation Problems
Hobbs
I got FSX Deluxe today and after running both disks and installing the game I get a notice saying:
"Flight Simulator cannot run because the version of Microsoft DirectX(R) installed on your computer is incompatible. Please reinstall DirectX 9.0 by running Flight Simulator Setup, or download the current version from www.microsoft.com/directx."
I have downloaded the November 2008 Update from several websites and I am able to run them and get to the point that it brings up the "Installing Components" screen and then a notice comes up saying:
"Setup has detected one or more DirectX component files are in-use by an application. Please exit all applications before running DirectX setup agian."
After that it brings up a screen saying that the installation has failed with a "finish" button. I have closed all files and tried agian, restarted my computer and tried, turned my computer all the way off let it sit and read it a story and tried agian, I have combed through the processes in Task Manager and removed any that I believe could have been using DirectX and tried all the combinations above agian.
I am running a Dell Inspiron 1525 with 32 bit Vista Ultimate, and haven't had problems with any other games up to this point (World of Warcraft, Age of Empires, Halo, ect.). I am sorry if this is a repeat thread, I've been all over the place looking for possible answers and haven't found anything. I figured that this would be the best place to find help.
Thank you,
Hobbs
Thank you,
Hobbs
Hi Hobbs
I think your problem is to do with User Privileges and Permissions.
Download the MS DirectX End-User Installer here.
Download details: DirectX End-User Runtime
Install by right clicking on the DX9 exe and selecting Run As Administrator.
Norm
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
Thanks for the advice Norm,
Unfourtounatly I still had the same problem. I downloaded and saved DirectX 9 from your link and ran it as an administrator and it still came up with the same error screen. I then tried installing it in safe mode with network (the thought process being that there would only be csrss.exe, winlogin.exe, and explorer.exe running) and yet agian it said that there were one or more component files in use.
Screenshot of the installer, error screen, and task manager:
Thank you,
Hobbs
Thank you,
Hobbs
Try this
Bring up task manager, close or "End Process" all the processes
under your name that aren't explorer.exe or taskmgr.exe
Try running dxwebsetup.exe again
Norm
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
Thanks Norm,
But I am still getting the same problem. Could it be that I have DirectX 9 already and that is why it doesn't want to install? In that case what could possibly be wrong between Flight Sim and DirectX? I have uninstalled and reinstalled it 3 times now as well as downloading all of the patches and running the repair and everything seems to be in order (from what I can tell going through the Program Files and my experiance with it at school - Taking an aviation class). Is there any way to uninstall/reinstall all DirectX files with out destroying to OS?
Thank you,
Hobbs
The dirextXwebupdate is just that, it updates the Directx files to Version 9c. You have a corruption there somewhere but I am not sure what it is. Your problem is not uncommon. Try googling your error message. There are many instances that appear but no obvious solutions
Norm
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
Norm,
Thanks for all of your help, to be honest I spent a good 6 hours working over this and looking through the internet (no joke from when I got home at 4-ish until I went to bed at 11) I have found other problems but none that are the same as mine, I have tried the solutions posted there to no avail. Do you think that uninstalling/reinstalling the OS (you can do that right?) would solve the problem?
Thanks agian,
Hobbs
Are you talking about Vista? This is a drastic step, you would lose any data ie emails, docs, photos etc you haven't backed up. A less intrusive option would be to uninstall FS, reinstall it as Administrator.
Norm
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
Okay, I'll try that and report back.
Thank you,
Hobbs
I just read that Antivirus can interfere with the installation of FSX. Try disabling it while you are installing.
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
Nothing...
After reinstalling FS agian as an administrator with my anti-virus off it still is having conflicts with DirectX. I have installed the same disks onto another computer (one that I do not have access to very often so it is not the answer) and it works just fine. This means that it is a problem with DirectX and not FS. I have looked for ways to uninstall and reinstall DirectX 9 (I understand it to be seperate from DirectX 10 meaning that it isn't woven into the OS itself) but havn't found anything. If anyone knows a way to do this or has any ideas as to how to fix this I would be greatly appreciative. The task of wiping everything and reinstalling it seems to be very daunting, and FS would provide a great benifit while I am working to become Certified so I don't want to give up on it.
Hobbs
Nothing...
Hobbs
Okay, the Dell Inspiron 1525 has an on board graphics processor GMA X3100 which will not run Microsoft FSX. You can look at the system requirements on
Flight Simulator X
Norm
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
