Hi i am having a problem with Adobe Flash Player.
It will not uninstall the event viewer error report is 1002+101.
I cannot uninstall from my control panel either.
As the popup says it's in progress off uninstalling please wait.
That happens every time i try uninstall Adobe Flash plus ActiveX.
With the Adobe>>http://download.macromedia.com/pub/flashplayer/current/uninstall_flash_player.exe>>this tool just hangs after 3/4 unistalled.
The task manager ends task of Adobe Flash uninstaller.
Thanks
Any clues help me fix this.
Toshiba Satellite M300/300 Notebook.
Intel Core 2 Duo T800.
2.1GHz) Duel Core Processor.
2 GB Ram.
320*GB SATA HD.
14.1" Wide Screen With Truebrite.
32 Bit Operating System.
Thanks
2 GB Ram.
320*GB SATA HD.
- Toshiba Satellite M300/300 IntelCore 2DuoT8100
- Processor Intel(R) Core(TM)2 Duo CPU T8100 @ 2.10GHz, 2
- HDAUDIO Soft Data Fax Modem with SmartCP
- 2GB (Max. up to 4GB)
- ATi Mobility Radeon HD 3470 (256MB discrete video)
- ATI Function Driver for High Definition Audio - ATI AA0
- 14.1 inch Wide Screen WXGA LCD
- Resolution 1280 x 800 x 60 hertz
- 320GB SATA Hard disk Drive C Local Fixed Disk S3A6586D005 NTFS File System Drive D CD Rom Disk
- PSU
- 75W (19V x 3.95A) 100-240V AC Adapter.
- Case
- Weight 2.166kg (may vary with spec)
- Cooling
- Fan/Air
- Microsoft USB Notebook Optical Mouse 3000 Intellipoint+T/Pad
- Standard PS/2 Keyboard
- Integrated 10/100/1000 Network Card Integrated Wireless LAN
- Other Info
- Toshiba Bluetooth™ V2.1 + EDR (Enhanced Data Rate) ATI Mobility Radeon HD 3470 (256MB discrete video memory and upto 1023MB shared video memory using HyperMemory technology with 2GB system RAM) Wireless Networking Integrated Intel 802.11 (a/g/n) Premium Harman/Kardon® speakers
