fingerprint?
Lewis_
i assume this is too do with the touchpad on my laptop but could someone please explain this driver too me?
the driver im looking at is this one:
Question again is im just wondering what it is, im running windows vista sp1, what software can i install too access this?
  • Internet Speed
    slow.
Hi Lewis_,
What is the make and full model number of your laptop?
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Can you double check your model number? The following list is from Sony, showing all laptops of type VGN-CR3... As you can see, your model is not listed.
Here is a link to the required driver, and also a link to the VAIO laptops that use this driver:
Driver Sony eSupport - VGN-CR390 - Software Updates & Drivers
List UPDFPD-14004800-US.EXE (check your model number against this list).
    Gigabyte IF233
i'm taking a stab-in-the-dark with this one, but i would guess by the name that it has to do with a fingerprint reader. i don't know, obviously, if yours has a fingerprint reader, but i state this because, at least in my case, the computer company may have had the software integrated into windows for a string of models in the same line. to give you an example, i have an acer aspire 5100 laptop and mine has preinstalled bluetooth drivers and has the bluetooth service too. but, my laptop does not have any bluetooth hardware! i would assume that the next model up, would have bluetooth hardware and every other spec the same as my model, so acer would save time and money by having a vista image they could deploy to many computers at the same time.
my two cents
    Garage PC
    Intel Pentium E3300 @ 2.5GHz
    BioStar G41-M7
    A-Data PC2-6400 (2 X 2GB)
    Diamond Radeon HD 4650
    Realtek
    HP Mx705 (CRT)
    1152x864
    LOGISYS PS480E12 480W
    Generic Barebones Case
    Stock Intel HSF
    Generic PS/2
    10 d / 1 u
Thats what i was thinking mpcrsc562, replying to dwarfs post, my laptop is a chinese model from sony, its not currently available elsewhere other than in china. if you run up a google search with my laptop model you will find the information on it, when i had to add drivers i had too do this and run google translator.vgn cr33 l - Google Search
ive got the driver installed Im just not sure on what it actually is, if its a finger print scanner id obviously have too add hardware too my laptop too access it ?
  • Internet Speed
    slow.
well, yes--if the driver in question is in deed a fingerprint scanner driver, and your computer does not have a fingerprint scanner, then you'd have to purchase one.
    Garage PC
    BioStar G41-M7
    Realtek
    HP Mx705 (CRT)
    1152x864
    Stock Intel HSF
    Generic PS/2
    10 d / 1 u
