Filemaker Pro 9 (Not Responding)
instantar
Installed FileMaker Pro v9 trial version on my Windows Vista Premium Laptop. Install went well but when I launched the program and pointed to any menu item I was greeted with "Filemaker Pro (not responding)". Uninstalled and Reinstalled FMP 9 several times. Filemaker support wasn't able to get it working either. I installed the trial version on another Windows XP machine without issue. Is anyone aware of any program conflicts?
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    Kingston PC3-10666 4Gb
    XFX 9800 GTX XXX
    Soundblaster X-Fi XtremeMusic
    2x Samsung SM-T220HD 22"
    1680x1050 on two monitors
    WD Raptor X/150Gb in RAID0 WD Raptor 36gb 3x Samsung F1 1Tb
    Thermaltake ToughPower 850w
    Thermaltake Armor
    Tuniq Tower 120
    Razer Diamondback 3G
    Dell Multimedia Enhanced USB
    Thermaltake Muse esata caddy
Used your suggestions. Found the Filemaker Pro folder and removed Read Only. The files in the folder are not Read Only but the Filemaker Pro Folder reset to read only. It also appears that Vista Administrator accounts have ownership.
I uninstalled the program using windows installer but found an additional folder named Filemaker Pro 9 that was not removed during the uninstall process. Don't know what to make of that. Unfortunately my problem still isn't solved.
Thanks for your help!!!
