Fan Speed Issue
Erekosa
I recently added memory to my Gateway FX 7026 quad core. After I was done with the process, during the post process an error flashed across (too quick to capture unfortunately), but it had to do with a Microsoft Handler of some sort. The net result is that my cpu cooling fan is running constantly at top speed now. I have had the system for 6 months and it has never run like this before.
Any ideas?
Hello Erekosa, welcome to Vista forums!
Seeing that you're having issues with new RAM installed and 'handler' issues; it may be that the 'new' RAM is bad! (it happens)
The best option would be to burn Memtesr86 to a CD and test each stick individually for at least one full pass.
Keep us informed!
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Hello Erekosa, and welcome to Vista Forums.
Is the new RAM the same type and speed as the old RAM?
If you have dual channel RAM, then double check that the RAM that is the same type and speed is installed in the same color RAM slots on the motherboard. You should have two slots per same color.
Hope this helps for now,
