Fan cooling control question
Does anyone know of a program that controls fan speeds? i want to turn up my fans higher but i dont know where to find a program that works well can some people give me links please?
    Custom built Desktop
    AMD Phenom II X6 1090T Black Edition 3.2Ghz
    MSI 890FXA-GD70 AM3 AMD 890FX
    8GB Adata Gaming series 2.0 DDR3 1600
    MSI Twin Frozr 5830 X2 with MSI 5850 Crossfired
    Asus 19", Acer 17"
    1400x900
    OCZ Agility 3 60gb, 500GB F3 Samsung Spin point and 5 other HDD's
    850W OCZ
    NZXT Phantom
    2 200mm fans with 6 120mm fans
    Logitec G9
    Saitek 2
    Major AMD, ATI and MSI Enthusiast.
Fan speed control program - Club MyCE
look at AZImmortal's post; u can't use software; the only software that is related is ones that monitor fan speeds. u can always buy a cheap hardware controller that yyou can change the speeds with from dials.
Dom
    Acer 5735z Laptop
    2.0 ghz intel pentium dual-core processor t4200 800mhz fsb
    Acer CathedralPeak Rev
    4gb
    Integrated Intel Graphics Media Accelerator 4500
    Realtek
    15.6" HD CineCrystal LCD
    1366x768
    160gb stock drive. ATA
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
well is there a program to monitor then? speedfan isnt working too well
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
It depends on what fans, and how they are connected.
ie CPU fans, case fans etc
Are they Molex connections, Connected to the mobo, Do they have PWM etc.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
depending on your BIOS settings the fans attached to motherboard headers will run 100% by default, the only one you can throttle through windows is the CPU HSF fan (providing its ''PWM'' enabled), via ''speedfan''
''speedfan'' will only alter fans that are ''PWM'' ready, these fans have a ''4pin'' connection to the board.
so...... what fans are you talking about & how are they connected to your system.
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
Why not just leave them all at 100%? Keeping is cooler is always a good thing.
    HP Pavilion DV7-1129wm Entertainment PC
    AMD Turion X2 RM-72 Dual Core @ 2.1GHz
    2 x 2 GB Hyundai DDR2 400 MHZ
    ATI Mobility Radeon HD 3200 @ 256 MB
    IDT High Definition Audio/SRS Premium Sound/Altec Lansing
    17" Laptop Screen
    1440 x 900 laptop, external 17 in LCD 1024 x 768
    WD Scorpio Blue 320 GB SATA 5400 RPM Toshiba 68 GB SATA 5400 RPM Second Drive (backup)
    8 Cell Lithium Ion Battery
    Laptop with "light up" HP Logo on outside
    Insane air coming out of Targus dual fan cooler
    Microsoft Wireless Mobile Mouse 3000 / Touchpad
    Full Keyboard with numpad
    Comcast Cable 20 MBps
    Used Primarily for CAD design using SolidWorks 2010. Also I love to watch HD movies using the HDMI output(Netflix). Linked to my Xbox 360 for Windows Media Center 3 USB ports + USB/eSata HP Remote for Windows Media Center and Quickplay Internal Dual Layer DVD+/-RW External HP Lightscribe Dual Layer DVD+/-RW HP Webcam and Microphone
Thats OK if you are gaming all the time, (like me), but it kinda gets noisy when just browsing the web.
naturalphenomen, can you tell us which fans you are talking about, the case fans or CPU/memory/GPU type fans.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Unless you have a proprietary motherboard (HP,DELL,GATEWAY,etc.), Speedfan should work with any computer. works fine with my 790i
    JUST ME/Custom Built
    Intel(R) Core(TM) 2 Quad Q9550 E0 2.83 Ghz @ 4037.5 Ghz
    EVGA NFORCE 790I SLI FTW Digital PWM
    8 Gig Corsair XMS3 DHX 1600 Mhz DDR3 CAS 9
    2x GTX 480's w/ Koolance VID-NX480's
    Creative SoundBlaster X-Fi Titanium (non-Fatal1ty) Edition
    Acer P243W 24" Premium Series
    1920 x 1200
    Seagate Barracuda 7200.11 1 TB HDD 32mb cache (3 Platters, 6 Heads model)
    Ultra X4 1050W PSU 76A Rated 12V SLI
    Antec 1200 Full tower ATX case
    x2 Thermaltake Blue LED 120mm 2800rpm fans, Zalman CNPS 9900
    Logitech LX310 2.4Ghz Wireless Laser Mouse
    Logitech LX310 2.4 Ghz Wireless Keyboard
    32mb Download, 12mb Upload from Comcast
    300$ custom watercooling setup. Antec 1200 big boy Radiator, Dual bay XPSC reservoir with clear bubble window, OCZ hydropulse 800L/H 12v pump, 12 ft tygon 1/2" ID, 3/4" OD tubing, Feser One UV Green 1 L fluid. (and VID-NX480 waterblock)
