I put a SD card in the computer and it never loaded.So I went to F: drive and it wasnt there!Most of the drives were gone there was just the J: drive.If I search for it its there but nothing loads up.What should I do?!
Can you post a screen shot of the Disk Management window?
To get the screen shot, go to Computer, Manage (or type Computer Management in the start search box), then Disk Management. Then look at these links if you need help attaching the picture to a post:
