external hardrive problem
mikeyb30
hi all im new to the forum:D
as i have very little knowledge of computers im hopeing one of you experts can help me!:geek:
im running vista home premium and Ive been trying to transfer all my old files and pics from a external hardrive which is hitachi ide that was out of my old laptop running xp
when i plug it in through the usb and look at my computer its not recognizing it but when i look in storage in computer management at the botton it says unknown disc not initialized so i am unable to browse the hardrive
any help would be great thanks
right click on the drive in the manage drives area and choose activate
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
    Intel Dual Core 3 GHz
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
Hi mike, can you post the screenshot of your disk management?
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
Can you check weather the External Hard drive is detected in device manager - and if not check weather the USB port that you connected the drive is working - check weather the USB controllers are Enable in BIOS
Now you see the Unknown Disk1 right click on it and click on Initialize and then check weather you are able to see it in My Computer.
Hope this Helps.
maybe try to right click in the gray area and choose format then Initialize.
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
