External floppy drive
ashton
Hi, I was wondering whether anyone could advise me on the following:
I recently bought a new PC that has the Windows Vista Home preloaded on it. It has no 3.5 floppy drive which I need as my family history files are all stored on floppy discs.
I bought an external floppy disc drive, it installed ok, but will not read or open the data on the floppy discs. I get the message "too many arguments." I can't view any jpeg files from my floppy discs as I receive the message "Vista photo viewer does not support this file." My saved text Word documents on the floppy disc will not open either, I get the message that the files are corrupt. Also, when I insert the floppy disc into the external drive, I am instructed to Format the disc before using. I just want the external drive to read the data!!
Any help or ideas would be appreciated.
Ashton.
Have you got a friend with a computer with a floppy drive that can move the data onto a cd?
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Thanks for your reply Roy. I had burned some files to CD, but when I export them into my family tree maker, they are read only files and I am unable to add any content.
They are read only because they are on cd.
You need to move them back onto your computer HD and add any comments/tags that way.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Thanks Roy - That worked! I placed the files on my hard drive as you said.
I also have the floppy drive working too as I went into Compatability on my PC, selected the drive and let the PC sort it out itself. It worked!
