Solved Extender Connection Issues
Extender Setup?
  • Sync Media Center to Extender
    Votes: 0 0.0%
  • Connection Troubles
    Votes: 0 0.0%
  • Total voters
    0
armyguyinfl
I have been having ridiculous amount of trouble setting up my Linksys DMA2200 extender and I am a tech. I finally set it up and I also creating some instructions on how to set up the extender properly. Hope this helps you in getting your extender to work and save you the time it took me. All the updates listed are required and I do not have Service Pack 1 installed. I am using the advanced firewall ON in Windows and not using LiveCare and running AVG and no problems. View my site to see the list of items required for configuration to get the Windows Media Center to work properly with the extender. Also, the other link below has all the codec's that the DMA Extender to work. If your extender drops connections constantly set your NIC card to not go into Power Save mode. If it continues then reset the extender (Button in Back) Note: Need to hold it for 30 seconds. Then, turn on the extender and reset to Factory. Repeat setup process. If extender continues to lose connection after turning off again then contact Linksys or Seller for replacement.
Extender Setup:
DanyK Imaging & Design © - Media Center Extender Connection Issues Resolution for XBox 360, DMA 2100/2200, Required Fix
DMA Codec's (Audio/Video) Supported:
Answer
    Custom Built by DanyKImaging.com
    Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core
    GIGABYTE GA-EX38-DS4 LGA 775 Intel X38 ATX Intel Motherboard
    G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800(PC2 6400) Dual Channel Kit Desktop Memory Model F2
    XFX PVT88PYDF4 GeForce 8800 GT 512MB 256-bit GDDR3 PCI-E SLI
    HD Audio Optical
    2 - Acer H233Hbmid Black 23" 5ms HDMI Full HD 1080P
    Two 1080p
    5 Drives Total 1- Western Digital ( 3 Segate's 1 Maxter 250GB
    Antec NeoPower 650 650W ATX12V / EPS12V SLI Ready
    Antec
    Internal Air Cooling System w/ Fan
    Logitech MX5000
    Logitech MX5000
    D - 26MB/s & U-2MB/s
    LITE-ON Black 4X Blu-ray DVD-ROM SATA LITE-ON 20X DVD±R DVD Burner with LightScribe Black SATA
