The Navigation pane's folder tree should be collapsed by default when you click on Computer in the Start menu. There is no way to prevent it from automatically expanding when you open a folder in the main window or from the folder tree though.
You could turn off the Navigation Pane and just use the Windows Explorer address bar to navigate. It jusy depends on how you like to navigate.
